C-Clips in the hub (lockout): POLL!
ebewley
6599
68
ZUKIWORLD Online, Editor
September 12, 2005, 07:03:28 AM »
The question has come up a couple of times in different discussions about using the c-clip in the hub (lockout). Some do and some don't.. So, this looks like a good time to post a poll and tally up the vote!
Thanks, Eric
Last Edit: September 12, 2005, 09:49:31 AM by ebewley
ZUKIWORLD ORDER
Today!
ed oorklep
637
1992 Suzuki Vitara
Re: C-Clips in the hub (lockout)
September 12, 2005, 07:31:39 AM »
I think it's there for a reason, but my new stronger CV's are on there way so I guess I'll see if it is needed
I've got one not on now I believe (haven't looked yet) but that makes some noise, so it might be not the best to have 'm out......
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Bobzooki
1754
2
Web Wheeler
September 12, 2005, 07:35:48 AM »
My Toyota CV axles have a C-Clip - but it seems to be there to hold it OUT, rather than IN, so I don't think it matters. Also, I've got a big flat-washer and bolt on the end of the axles - I do have THAT installed.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: C-Clips in the hub (lockout): POLL!
Reply #3 on:
September 12, 2005, 10:14:35 AM »
The one under the hub? Its there to stop the shaft pulling out of the hub at full droop. If the shaft pulls back then the wheel bearings are exposed and can get full of crud. Of course if you're CVs are on the limit and you only drive in rocks then leaving it off might save you a breakage.
http://www.rhinopower.org
blacknight
987
Reply #4 on:
September 12, 2005, 11:31:34 AM »
I've had my pull out with c-clip in
George
SnoFalls
1358
3
Reply #5 on:
September 12, 2005, 12:52:26 PM »
I'm running my trac/kicks with 'em, just cause I've had no reason to not ...
If I was breakin CV's, I'd probably do the mod to have the pass side like the drivers, and then without a the clip could change either CV in about 5 minutes
Rhinoman
4502
36
Reply #6 on:
September 12, 2005, 02:31:19 PM »
Quote from: blacknight on September 12, 2005, 11:31:34 AM
I've had my pull out with c-clip in :-[ÂÂ
George
Time to check how much CV travel you have left at full droop.
mesjr2004
422
Reply #7 on:
September 12, 2005, 03:37:51 PM »
never put them back in my sammy or anything else . i was breaking a birfield or 2 every time i went wheeling , so if it didnt keep it from working properly it didnt go back in . especally that clip on the axel that holds the birfield in . wow some of thoes are a bitch to get apart.
Digger
1991
1996 Suzuki X-90 4X4
Reply #8 on:
September 13, 2005, 07:47:38 AM »
This needs to be more specific. Sammys use a c-clip that holds the lock-in/lock-out hub onto the end of the axle splines and Trackers use a c-clip under the lock-in/lock-out hub to hold the cv splines into the spindle/wheel bearing...
ed oorklep
637
1992 Suzuki Vitara
Reply #9 on:
September 13, 2005, 09:15:28 AM »
If you have a lifted one (trackkickvit) you should leave them in , I have one out (left side) and only have RWD it'll be fixed quickly enough but it's anoyying when you want to make some poser shots
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
lil_Truck
1148
Eric Gardner
Reply #10 on:
September 13, 2005, 03:51:18 PM »
I left them out and used a bolt and washer (the end the the shaft is threaded) to hold the axil in. Never had a problem with them falling out. Braking, yes, falling out no.
32 MTR's Warn 8000i
