depends, if you want your tracker to ride like a caddy then OME. but if you want flex but a harsh ride then calmini.stu
Or you can mix and match parts with the Calmini lift and have a decent riding, good clearance, good flexxing lift
I was just at rock roads web sight and know I'm a little confused does there kit use the ome rear shocks or dosetech? are the dostech longer or better? are they $80 more or what? do I need a drive shaft spacer on 2.5" lift?
what is a rear diff spacer? Is it like a drive shaft spacer or something else?
