calmin or ome lift?
  • 17 Replies
  • 5670 Views
Offline nevadasmith
  • 112
  • hey, wait wait I got a new idea!
calmin or ome lift?
« on: November 14, 2004, 03:50:37 AM »
Hey Im going to order a lift monday or tuesday. and wile im sure this quest has been asked befor but,,,,, for my 91 tracker which is better? i want 2 1/2-3" of suspention lift. Also is this enough to clear 30x11.5's or do i need a body lift to?
92 hardtop removable + swampers + 2.5" lift+ locker+ onboard air
Offline 1bigtracker
  • 3409
Re: calmin or ome lift?
« Reply #1 on: November 14, 2004, 05:20:54 AM »
depends, if you want your tracker to ride like a caddy then OME.  but if you want flex but a harsh ride then calmini.
stu
Offline explosivo
  • 3157
« Reply #2 on: November 14, 2004, 07:09:23 AM »
stu
Or you can mix and match parts with the Calmini lift and have a decent riding, good clearance, good flexxing lift ;)
omghi2.us[/url]
Offline Speedracer7c
  • 2210
« Reply #3 on: November 14, 2004, 07:34:35 AM »
For twice the cost!
Offline 1bigtracker
  • 3409
« Reply #4 on: November 14, 2004, 07:57:02 AM »
humm, make me think about how OME struts would work with a calmini 2in. :D
stu
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: November 14, 2004, 07:58:53 AM »
I've run the OME on both the swb and lwb. In my opinion it rides and handles better than the stock setup. Good at speed and and an easy install. I'd suggest using this with coil spacers, camber bolts, longer rear shocks than the OME and a spacer for the rear diff. I now have the Calmini 3" with the OME struts and ARB winch bar and winch on my lwb. Firm is the furthest from the description I would use. It has a very soft ride and flexs much more. I don't like the way it uses the springs as bumpstops but that's fixable. I find the nose dives more on hard braking causing the rear to unweight and lock the rear brakes more easily. It will give you more flex offroad, is built strong and you can mod it further if you want.
Offline 92Sidekick4x4
  • 1456
« Reply #6 on: November 14, 2004, 09:44:01 AM »
i have only heard things baout the 2 different companies, don tknow anyhting abotu them really cuz i dont have their products, you will be able to fit 30"x9.5"s on there with no lift at all, well at least i did
Offline nevadasmith
  • 112
« Reply #7 on: November 14, 2004, 02:09:07 PM »
hey thanks for all the in put I think i'm going to go with the ome lift. if for no other reason than idont have to drop the frount diff and in nevada the smoother the ride the better!!!
??? what is a rear diff spacer? Is it like a drive shaft spacer or something else?
  • 2210
« Reply #8 on: November 14, 2004, 02:10:23 PM »
Yeah, driveshaft spacer, I have it, works like a charm.
Offline nevadasmith
  • 112
« Reply #9 on: November 14, 2004, 02:37:50 PM »
I was just at rock roads web sight and know I'm a little confused does there kit use the ome rear shocks or dosetech? are the dostech longer or better? are they $80 more or what? do I need a drive shaft spacer on 2.5" lift?
spinaltap
« Reply #10 on: November 14, 2004, 03:03:36 PM »
The RR kit comes with the DT shocks. They have more travel than stock. You don't need a spacer with the 2.5" lift. If you want a soft ride then get the lighter springs...I have the heavier springs in mine and the ride is very firm...but I like it that way.
Offline nevadasmith
  • 112
« Reply #11 on: November 14, 2004, 03:13:16 PM »
thanks for all the help guys!!!!  ;D
Offline Bfunk
  • 406
« Reply #12 on: November 14, 2004, 04:06:46 PM »
stu
On my rig the Calmini lift rode AWESOME.  The thing that I know I will regret the most about changing out running gear is losing the ride on rough trails :'(
Brian
Offline cj
  • 1276
« Reply #13 on: November 14, 2004, 07:16:45 PM »
Nope, have a look here  http://www.cabrito.suzukioffroad.com.br/Upper%20wishbone.htm
« Last Edit: November 14, 2004, 07:26:17 PM by cj »
Offline nevadasmith
  • 112
« Reply #14 on: November 16, 2004, 03:29:55 PM »
now I see the light, keeps the ball joint on the third link from binding is there a web site or place to order it in english?
