CARB TROUBLES!
CARB TROUBLES!
suzi_n_sammy
184
Rock the Sam
CARB TROUBLES!
September 10, 2004, 03:24:13 PM »
I hate the freakin Hitachi carb!!!! Ok so i rebuilt it , new jets, gaskets yada yada yada. Which i regret doing now, i should have bought a Weber
But now to keep it from just dieing when i start it because the idle is too low i cranked it up. so when i start it the choke is working and it idles at 2000. then when it warms up the choke dies and i have to keep my foot on the gas a little to keep it running when i let it idle. how do i remedy this?
( i know 2 threads in 15 minutes im on fire right?
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
zukiboy
42
Wheel Forever !!!
Re: CARB TROUBLES!
September 10, 2004, 04:38:12 PM »
I just rebuilt mine and I have the exact same troubles. I can't figure what went wrong.
88 sami
3"lift 30's
No matter where you are there you'll be
bbagwell
278
3
Re: CARB TROUBLES!
September 10, 2004, 08:34:16 PM »
I would rather have a good factory carb then a Weber. When the factory carbs are working right they are hard to beat.
2002 Suzuki Grand Vitara
1983 Toyota PU
jerryp58
449
Re: CARB TROUBLES!
Reply #3 on:
September 10, 2004, 11:39:33 PM »
I've never had a Hitachi carb and it's been a long time since I opened a carb up.
I'm sure it could be a lot of things, but a bad float adjustment is the first thing that comes to my mind.
Jerry
1990 Geo Tracker, 2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
suzi_n_sammy
184
Rock the Sam
Re: CARB TROUBLES!
Reply #4 on:
September 11, 2004, 02:57:33 AM »
im pretty sure I got the float bowl. i measured the travel up and down on it before and after and its the same and i never had the problem before i rebuilt it. . .
95XL7
Re: CARB TROUBLES!
Reply #5 on:
September 11, 2004, 08:46:55 AM »
Whats a carb? Didn't they have those on model t fords?
suzi_n_sammy
184
Rock the Sam
Re: CARB TROUBLES!
Reply #6 on:
September 11, 2004, 08:49:42 AM »
lol yea
but were not all cool enough to have a fuel injected engine (not yet at least)
jerryp58
449
Re: CARB TROUBLES!
Reply #7 on:
September 11, 2004, 11:55:27 AM »
So, at the proper idle speed, it stalls?
Can you richen the mixture with an air/fuel mixture screw?
Are there any vacuum lines on the carb? If so, did you double check to see they're all hooked up where they should be?
Jerry
zukiboy
42
Wheel Forever !!!
Re: CARB TROUBLES!
Reply #8 on:
September 12, 2004, 03:48:04 PM »
I found my trouble, I took a can of carb cleaner with a tube nozzle on it and sprayed around the carb and vacuum hoses. I found a crack in one on the manifold in front of the carb,now it runs great. When the carb spray finds the leak the engine runs good till it burns it up. Good luck with yours.
88 sami
3"lift 30's
jerryp58
449
Re: CARB TROUBLES!
Reply #9 on:
September 13, 2004, 03:48:43 AM »
... but hopefully that's a seriously misplaced/ambiguous pronoun... "the engine runs good till
it
burns it up"
Jerry
trackermad
150
Re: CARB TROUBLES!
Reply #10 on:
September 13, 2004, 05:07:45 AM »
First I have to admit that I have never worked one one of these carbs but I have done lots of others so Ill tell you what I would to to trouble check. First check each vaccume line seperatly make sure they are all connected to the correct port (I hope you have a schematic). Next check your base gasket for leaks use the carb cleaner trick listen for a surge in engine speed. Grab the throttle lever and feel if there is any up down play in it thats a leak that gets worse over time. Once you have checked all this its Idle circut time. With the engine and choke warmed up. I don't know the base Idle screw settting but I guess just start where it is. you will need a tach for this. turn the mixture screw out untill the engine reaches its peak rpm then turn the screw back in untill the rpm drops back down 50 to 75 rpm. If there is more than one screw you need to adjust them evenly together and make sure they start from the same point. Now you should be able to adjust you idle speed screw to your desired Idle rpmIf you diddnt bend your choke linkage when you took the carb apart you shouldnt have to mess with it. Some carbs have a seperate screw to adjust your high idle others use the same screw that is used on the low speed. If its the later and your high speed is still to high some carbs have a vaccume pull off for the choke. If that isnt working right it will sit to high on the cam and that could be the issue. If you post some pics of the outside of the carb I might be able to give you a better answer.
Hope this helps
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so." ~Bertrand Russell
