toyota running gear
  • 2220 Views
Offline da_mtg_man
  • 58
toyota running gear
« on: September 05, 2008, 04:00:30 AM »
I found a toyota P/U that a guy is dropping a 350 into so he is parting out some original stuff.
Will this stuff fit under the Sami?
rear end (8" with 4.10 gears), front end with matching gears, cv axles,
Some people are like Slinkies...
Not really good for anything,
But they still bring a smile to your face when
you push them down a flight of stairs.
Re: toyota running gear
« Reply #1 on: September 05, 2008, 09:43:54 AM »
The front end is going to be the problem.  You will need an axle from a pre-86 Toy as it sounds like your buddy has an IFS front end.  I would pick up the hardware then hold onto it until  you can find a front axle to put your gears into.  There are a couple of companies that make Toyota axle conversion kits, with either stock or YJ springs.  You can't go wrong with any of them.
Offline Amilla
  • 1076
« Reply #2 on: September 05, 2008, 12:54:23 PM »
For a Samurai or a track/kick?
Amilla
Offline da_mtg_man
  • 58
« Reply #3 on: September 05, 2008, 07:09:54 PM »
Thanks Drone.
Aamilla, It's a Samurai.
« Reply #4 on: September 05, 2008, 09:12:35 PM »
IFS sami could be interesting....
Offline Amilla
  • 1076
« Reply #5 on: September 06, 2008, 10:13:26 AM »
Defiantly a step in a different direction.
Try and find a 79-85 front end (84-85 are the ones to try and get, but others will work.)
Amilla
