toyota running gear
toyota running gear
da_mtg_man
58
toyota running gear
September 05, 2008, 04:00:30 AM »
I found a toyota P/U that a guy is dropping a 350 into so he is parting out some original stuff.
Will this stuff fit under the Sami?
rear end (8" with 4.10 gears), front end with matching gears, cv axles,
Some people are like Slinkies...
Not really good for anything,
But they still bring a smile to your face when
you push them down a flight of stairs.
Drone637
8121
116
Evil Cow
Re: toyota running gear
September 05, 2008, 09:43:54 AM »
The front end is going to be the problem. You will need an axle from a pre-86 Toy as it sounds like your buddy has an IFS front end. I would pick up the hardware then hold onto it until you can find a front axle to put your gears into. There are a couple of companies that make Toyota axle conversion kits, with either stock or YJ springs. You can't go wrong with any of them.
Amilla
1076
Toyota running gear was made for a samurai!
September 05, 2008, 12:54:23 PM »
For a Samurai or a track/kick?
Amilla
da_mtg_man
58
Reply #3 on:
September 05, 2008, 07:09:54 PM »
Thanks Drone.
Aamilla, It's a Samurai.
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #4 on:
September 05, 2008, 09:12:35 PM »
IFS sami could be interesting....
Amilla
1076
Reply #5 on:
September 06, 2008, 10:13:26 AM »
Defiantly a step in a different direction.
Try and find a 79-85 front end (84-85 are the ones to try and get, but others will work.)
Amilla
