fuel pump
  • 25 Replies
  • 5098 Views
Offline bus_driver
  • 479
Re: fuel pump
« Reply #15 on: October 24, 2005, 12:33:03 AM »
gonna start from back to front chenking everything you guys have pointed out too look at
will andy ecm fomr 89 - 94 ish work on this thing?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Re: fuel pump
« Reply #16 on: October 24, 2005, 12:35:09 AM »
No, early ECMs are different, and I don't know
how interchangable the years are, Zaggy was
saying keep it the same year ECM
Offline bus_driver
  • 479
Re: fuel pump
« Reply #17 on: October 25, 2005, 12:26:09 PM »
well definately the fuel pump as the relay is clickin on and off which I wiould assume the ecm is telling it to activate and now the pump is just preoccupied with looking around,  so will definately be changing it
thanks again for all the help
92 2dr soft top
235/75/15
2 inch lift
custom mud
Re: fuel pump
« Reply #18 on: October 25, 2005, 01:29:41 PM »
Thats not a good sign. I think someone else had this problem before (Ed?) and it was the ECU fried.
Offline zaggy
  • 1134
Re: fuel pump
« Reply #19 on: October 25, 2005, 01:42:33 PM »
Before you change the fuel pump...
Check if you have fuel pressure...even if it's just disconnecting the supply line and seeing if it squirts.
The problem you're describing may be an ECU issue..if you got pressure, or squirt then it's the ECU if you don't then it's the pump.
ECU's have a pretty narrow interchange, 89-90 specific to automatic/standard, 91-93 Specific to automatic/standard, then 94 up.
Numbers should match and watch out for CAN...US decals as well.
Zag
Offline bus_driver
  • 479
Re: fuel pump
« Reply #20 on: October 26, 2005, 12:40:30 AM »
doesn't the ecm tell the relay to turn on and off and the relay tell the pump to pump or not?
so if the pump is not running and the relay is clicking then the ecm should not be in the link?
but will definately check the pressure first...
92 2dr soft top
235/75/15
2 inch lift
custom mud
Re: fuel pump
« Reply #21 on: October 26, 2005, 04:51:40 AM »
I might have misinterpreted what you said. I read that as the Relay was clicking ON and OFF continuously. Did you mean that it just clicks on and off normally?
There are 2 relays involved, the ECU turns on the main relay when it 'wakes up', that powers the ECU ancillaries and sensors. Then there is the Fuel Pump Relay itself. The fuel pump is switched on for 3 seconds when the ignition is turned on, it is also turned on during cranking and remains ON while there is an ignition trigger signal (ie while the engine is running). It is switched OFF something like 3 secs after the last ignition trigger pulse (can't remember exactly). It shouldn't be switching on and off.
If that is OK then chances are its the pump or the wiring to it.
« Last Edit: October 26, 2005, 04:57:59 AM by Rhinoman »
Offline bus_driver
  • 479
Re: fuel pump
« Reply #22 on: October 26, 2005, 06:23:05 PM »
Rhino you are correct for about 3 second and then off and on while cranking but no pumpy is working soooo
I got hte pump today and then cut the hole in the trunk area but the curve of the bod is in the way of getting it out so will have to drop the tank a bit but..............
the are 2 wires on top of the pump housing that are like gooped on ...... it broke   what now???? it llooks like the hot lead (red) can I just goop it back on?
92 2dr soft top
235/75/15
2 inch lift
custom mud
Re: fuel pump
« Reply #23 on: October 27, 2005, 08:28:09 AM »
No, the goop was under coating to prevent rust,
you got to dig thru that stuff to get to the screws
that connect the wires to the pump head.
You are going to have to drop the tank to get the
pump out, you need 4" minimum to get it out, I can
remove mine with out dropping the tank, and I have
4" body lift, it was a little tight tho, and watch out for
that plastic strainer on the bottom of the pickup, it
won't fall off easy, but it does come off.
You are going to have to solder the connections back
on, or get some new connectors that solder on, or crimp
ons, but I hate those things, they always fall off when
you least expect it
Offline bus_driver
  • 479
Re: fuel pump
« Reply #24 on: October 28, 2005, 10:21:32 AM »
well got the pump out and then decided to try it ........works fine...... so checked the relays again and the are fine clikedy clickedy and then I decided to work the wiring back to front found the first connector and it was fine then I got to the one in the rear tail lite and a wire fell off in my hand........no not the pump one but once i trace the color change the wires are shot to hell......did someone tell me to check there?......nah....... I will listen next time any way will clean up wire and try it again probably get rid of the connector all together and hard wire it.
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: fuel pump
« Reply #25 on: October 28, 2005, 10:38:06 AM »
The other thing to check is the wiring. There's a large junction plug in the harness behind the left tail light that gets corroded, sometimes causing the pump to quit working from lack of power getting to it... The plug becomes especially susceptible to corrosion if there is any holes under the tail light...
Good luck! ;) ;D
