fuel pump
  • 25 Replies
  • 5041 Views
Offline bus_driver
  • 479
  • the voices tell me different things
fuel pump
« on: October 17, 2005, 01:00:48 PM »
fuel pump on 92 kick 2 door.......heard that there my be a trap door from trunk under the carpet ???? yes no??
gotta change mine and it will cost me $225 I guess that was not the GM side of things cuz they are only $100 usually.....love my truck, love my truck
I will just keep saying it
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline explosivo
  • 3157
Re: fuel pump
« Reply #1 on: October 17, 2005, 01:46:30 PM »
No trap door. Gonna have to drop the tank :-/
omghi2.us[/url]
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
Re: fuel pump
« Reply #2 on: October 17, 2005, 02:34:18 PM »
I'm in the process of replacing my rear floor,and I'm gonna add an excess panel to get to my tank. The tank is a mofo to remove. I will post pix tomorrow, after I cut out the rusty floor it took me like 15 min to pull the tank with no problems.
If I Can't Weld It          It Can't Be Welded
Offline SnoFalls
  • 1358
Re: fuel pump
« Reply #3 on: October 17, 2005, 03:10:27 PM »
wow ... stock location took me about 20 minutes to remove (and that was half full of fuel) ...
what problems are you having dropping the tank (this is probably the easiest car I've ever had to do that to).
Re: fuel pump
« Reply #4 on: October 17, 2005, 05:13:50 PM »
You could remove the rear 6 body bolts and
lift the body up instead, 4" will clear the pump
assembly
Offline ghd23
  • 406
Re: fuel pump
« Reply #5 on: October 18, 2005, 09:46:07 AM »
        Dropping the tank was not the prob. The prob was getting at all the lines and plugs. A persons arms can only bend at the joints especially when you are laying on the ground.
Offline SnoFalls
  • 1358
Re: fuel pump
« Reply #6 on: October 18, 2005, 10:38:02 AM »
If I recall ...
1) pull the line from the fuel filter (easy)
2) unbolt the filler at the top and push it thro the body (easy)
3) lower the tank an inch or so
2) get the 2 hoses for the return line and canister off (tight, but droppin the tank a few inches get's ya some room)
4) pull the filler (+ it's extra hose) outta the connection to the tank (agin that 2" drop helps)
Offline bus_driver
  • 479
Re: fuel pump
« Reply #7 on: October 18, 2005, 12:35:05 PM »
yeah looking at just cutting the hole thru the floor since I'm sure the bolts on this thing are rusted like all the other ones but will see tomorrow thanks for the input guys
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline prairie_dog
  • 234
  • 85/413 tin top
Re: fuel pump
« Reply #8 on: October 18, 2005, 08:43:00 PM »
 Did you test it to find out it's toast?
 I just fixed one on a 90 kick I got, thought the pump was dead but when I took it out I gave it some lov'in with a ball peen ( power still hooked up just out of the tank) it fired right up.
Judging from what was in the bottom of the tank the pump just got stuck ???
That was 2 weeks ago and it still runs fine
 Steve :)
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: fuel pump
« Reply #9 on: October 18, 2005, 10:36:24 PM »
The other thing to check is the wiring. There's a large junction plug in the harness behind the left tail light that gets corroded, sometimes causing the pump to quit working from lack of power getting to it... The plug becomes especially susceptible to corrosion if there is any holes under the tail light...
Offline chet
  • 556
  • Zuki time!
Re: fuel pump
« Reply #10 on: October 19, 2005, 12:01:37 PM »
one last thing is the computer as well. The fuel pump is a common failure in the computer.
Re: fuel pump
« Reply #11 on: October 19, 2005, 01:25:24 PM »
Have you checked the relay?
Offline ghd23
  • 406
Re: fuel pump
« Reply #12 on: October 19, 2005, 04:18:02 PM »
Look at the post Rust, Rust and more Rust !!
Offline bus_driver
  • 479
Re: fuel pump
« Reply #13 on: October 20, 2005, 11:04:34 PM »
well got to the parents house and started the truck up and runs fine ??????
dunno
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline bus_driver
  • 479
Re: fuel pump
« Reply #14 on: October 24, 2005, 12:20:03 AM »
ok so problem has come back and gone again and definately to do with fuel pump or activation of said fuel pump ..... relay under ?  I have it intermittently and when it does stall you wait a few seconds after starting turning the key b4 starting and then she fires.
92 2dr soft top
235/75/15
2 inch lift
custom mud
