distributor swap
  • 1528 Views
Offline Spitfire Rick
  • 123
  • fun lovin criminal
distributor swap
« on: March 11, 2009, 06:18:05 PM »
will a distributorfrom a 1.3 fit into a 1.6 8v
If I have to understand don't bother explaining
Re: distributor swap
« Reply #1 on: March 13, 2009, 07:10:17 AM »
You need to use the adapter from the 1.3 or grind the end of the shaft off the dizzy.
  • 6589
« Reply #2 on: March 13, 2009, 09:09:19 AM »
Are you sure Rhinoman? I think that the 1.3 dizzy from a Samurai installation will slide right into the 1.6 8-valve Sidekick / Vitara engine. I'm not 100% but I think I've done that though...  ???
  • 123
« Reply #3 on: March 13, 2009, 09:49:25 AM »
 I just swaped distributors the 1.3 was longer than the 1.6 below the gear I just swaped the adaptor only 3 bolts 1.3 dist. is now nicly installed on 1.6
