gear lube
gear lube
bhmudder11
22
gear lube
June 09, 2008, 10:24:09 PM »
can someone tell me what weight and how much gear lube you should put in the frount and rear differental.
my ride is a 1987 samurai
thanks
wildgoody
8134
67
Re: gear lube
June 09, 2008, 11:02:21 PM »
80-90 will be fine and each end takes about 1 quart
bhmudder11
22
Re: gear lube
June 09, 2008, 11:39:56 PM »
thanks for the help. is there any other oils i should change beside that and the motor oil. im dont know all the terms in the truck world. im new to this. im an atv guy
Jeremiah
1880
Viva La ZUKIWORLD!
Re: gear lube
Reply #3 on:
June 10, 2008, 12:43:26 AM »
If it's a new vehicle (to me), I check / change all the fluids...
Transfer case, bleed the breaks, flush & replace coolant, suck out & replace power steering fluid, check the belts, cap & rotor, timing belt...
bhmudder11
22
Re: gear lube
Reply #4 on:
June 10, 2008, 10:56:53 AM »
were do i fill up the transfer case oil. what do i use and how much. and would that be considered the transmission
Jeremiah
1880
Viva La ZUKIWORLD!
Re: gear lube
Reply #5 on:
June 10, 2008, 04:02:09 PM »
Go here:
http://www.acksfaq.com/
Get the Field Service Manual (FSM). It will tell you all (location, pics, quantity of fluids, Method of Procedure etc.). It's got just about all you'll ever need to know about your samurai.
And, the transfer case and transmission are two separate entities.
bhmudder11
22
Re: gear lube
Reply #6 on:
June 10, 2008, 04:19:56 PM »
thanks. thats what i needed.
bhmudder11
22
Re: gear lube
Reply #7 on:
June 10, 2008, 04:46:05 PM »
i cant find the service manual for a 1987. will the 1988 work for my sammy
rascott
669
15
tread lightly monkeywrench a little
Re: gear lube
Reply #8 on:
June 10, 2008, 06:00:54 PM »
if you search around, i'm sure you can find a fsm for your year.
for basic service info, a chilton's will give you most of what you need and enough procedural advice on how to do it.
more technical stuff gets left out.
bhmudder11
22
Re: gear lube
Reply #9 on:
June 10, 2008, 06:33:10 PM »
thanks i found one. but will 80w90 oil work without problems instede of 75w90. it gets very hot here and i have a bunch of 80w90 oil
Drone637
8121
116
Evil Cow
Re: gear lube
Reply #10 on:
June 10, 2008, 11:33:35 PM »
80/90w shoudl be fine. I believe that is what I run in my SJ.
bhmudder11
22
Re: gear lube
Reply #11 on:
June 11, 2008, 01:09:30 AM »
thanks yall. i got the fsm so im good to go. got some work tommarow
