Engine Swap
  • 8 Replies
  • 2581 Views
Offline Yoak
  • 577
Engine Swap
« on: December 27, 2005, 07:56:14 PM »
Hey All,
Im running a 93 Kick, 2WD for the moment...going to get it converted to 4x4....after the first of the year....
I am currently running a 8V...I have a turbo for it (have pics if people want to see), but for the ammount of work it needs im thinking of swapping the engine out...
Right Now I am leaning towards a 16V....Not OBD II....
I have also heard great things about the 2.0, 2.7 V6 (XL7)  etc but I have been told getting it to pass emissions is pretty difficult...as it is obd II
.Ive done most of my own work, and feel fine swapping in a 16v, but the headache, and prices im getting quoted for a 2.0 doesn't make it seem worth while....
Any recomendations
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
Re: Engine Swap
« Reply #1 on: December 27, 2005, 10:11:58 PM »
What is the horsepower you get out of a 2.0? I'd say go for the 16v, and if you want to deal with the headaches of OBDII go all the way to the 2.7.
Just my opinion, I have a 1.3L right now  ;D
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Offline 99Trackerconv
  • 430
  • I love my Tracker
Re: Engine Swap
« Reply #2 on: December 27, 2005, 11:08:27 PM »
2.0 is rated at 127hp 130tq
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline Yoak
  • 577
Re: Engine Swap
« Reply #3 on: December 27, 2005, 11:11:25 PM »
XL 7 is rated at around 180, but will need a custom motor mount
16V basically a bolt in (apx 100 hp stock), but needs harness /ecu
2.0 needs cutom flywheel and mounts
Offline BV1
  • 58
  • X-90 fan :)
Re: Engine Swap
« Reply #4 on: February 17, 2006, 12:58:10 PM »
Do the bellhousings bolt together? Can I use at stock trans with the 2.0 eng?
-Steve
  • 6587
Re: Engine Swap
« Reply #5 on: February 17, 2006, 03:01:57 PM »
-Steve
There is some interchangeability. Try doing a search for this... we were talking about the 1.8 and the 2.0 working with stock Sidekick (1.6) transmissions earlier last year. I know I have a 1.8 bolted to a 2wd 1.6 Sidekick transmission using the 1.8 flywheel and clutch. I "think" [do the search] that someone said the 2.0 needed a thinner flywheel to work.
Good Luck, Eric
Offline billybob
  • 23
Re: Engine Swap
« Reply #6 on: February 17, 2006, 04:20:11 PM »
I did the OBDII swap 1996 tracker 2WD auto inna 88 sami and pulled the harness outta 95 (OBDI) to make everything kosher. Now i would recommend that you do all of your research as to what has to be done in order for that rig to pass smog PRIOR to starting. I found out that OBDII has to have all of the EVAP system sensors in working order for the rig to pass smog... OBDI has 8 (I think) whereas OBDII has 12-16. All that means is that if you have a bad sensor (something as simple as a bad gas cap) you fail. The plus side to OBDII is the computer compatability.... you can re-program them :)
BTW, I got mine to pass smog here in Kali... and that's tough.
L8R :P
billybob_CA
Offline takai
  • 907
Re: Engine Swap
« Reply #7 on: February 17, 2006, 04:27:24 PM »
I put the 16V in my Sami and love it. My wife has a 4-door Tracker with the same engine. I don't think that you would be disappointed with this swap.
'Cause, I am to misbehave.
95XL7
Re: Engine Swap
« Reply #8 on: February 17, 2006, 04:33:59 PM »
Mine passes emissions even with the main cat gutted. It still has the 2 pre-cats.
I don't tell them it's a 2001 engine and they don't ask. Here in Wisconsin 95 and prior they run on the wheel dyno to check emissions.Mine passes 1995 levels fine.
1996 and later they plug into the OBDII conector
and if there is no codes you pass.
I have managed to get it so no codes are present now
anyways.
