exhaust leat at manifold
keith
1176
3
October 06, 2004, 11:35:59 AM »
On my 90 Tracker I have an exhaust leak where the down pipes meet the manifold. The pipes feel solid, not rusted out. When I put my hand in front of the clamp that holds the pipes to the manifold I feel exhaust coming out. Is it likey that the claimp is just loose? Can the gaskets wear out? Or is there a rust hole I am not seeing in the down pipe?
Thanks,
wildgoody
8134
67
Re: exhaust leat at manifold
October 06, 2004, 12:00:56 PM »
It's a hole or missing bolts, there
is no clamp, just 3 nuts on the studs
that come out of the manifold, I have
one from the 89 Turbo Kick that has a
broken stud too, so you might have the
same problem
Mike71
1449
October 06, 2004, 12:08:39 PM »
i have the same leak..really makes the car stink sometimes lol if i keep the car i will just goto the calmini perf. exh combo
i think my leak is from a bad gasket i had a bad 02 so my exh mani. got glowing hot more then once before i finally changed the 02 i think that ate the seal up
623hp kb cobra sold! 100hp kick new DD
keith
1176
3
Reply #3 on:
October 06, 2004, 10:54:11 PM »
2 of the bolts were loose enough that I could hand tighten them. I tightened them, but the leak is still there. Do I have to do something special to seat the downpipe? If the bolts were that loose maybe it is not mating up flush with the manifold.
Cwkick
888
Reply #4 on:
October 07, 2004, 01:45:45 AM »
I bet the exhaust doughnut cracked or blew out so it is not sealing anymore.
Cwkick
Digger
1991
1996 Suzuki X-90 4X4
Reply #5 on:
October 07, 2004, 02:03:48 AM »
My 90 Tracker has an occasional leak there, too. Just crank the nuts down and that should seat the pipes together. From what I recal, there is no actual separate gasket or donut at that junction, just a tension fit...
