exhaust leat at manifold
  • 2712 Views
Offline keith
  • 1176
« on: October 06, 2004, 11:35:59 AM »
On my 90 Tracker I have an exhaust leak where the down pipes meet the manifold.  The pipes feel solid, not rusted out.  When I put my hand in front of the clamp that holds the pipes to the manifold I feel exhaust coming out.  Is it likey that the claimp is just loose?  Can the gaskets wear out?  Or is there a rust hole I am not seeing in the down pipe?
Thanks,
Re: exhaust leat at manifold
« Reply #1 on: October 06, 2004, 12:00:56 PM »
It's a hole or missing bolts, there
is no clamp, just 3 nuts on the studs
that come out of the manifold, I have
one from the 89 Turbo Kick that has a
broken stud too, so you might have the
same problem
Offline Mike71
  • 1449
« Reply #2 on: October 06, 2004, 12:08:39 PM »
i have the same leak..really makes the car stink sometimes lol if i keep the car i will just goto the calmini perf. exh combo
i think my leak is from a bad gasket i had a bad 02 so my exh mani. got glowing hot more then once before i finally changed the 02 i think that ate the seal up
Offline keith
  • 1176
« Reply #3 on: October 06, 2004, 10:54:11 PM »
2 of the bolts were loose enough that I could hand tighten them.  I tightened them, but the leak is still there.  Do I have to do something special to seat the downpipe?  If the bolts were that loose maybe it is not mating up flush with the manifold.
Offline Cwkick
  • 888
« Reply #4 on: October 07, 2004, 01:45:45 AM »
I bet the exhaust doughnut cracked or blew out so it is not sealing anymore.
Cwkick
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #5 on: October 07, 2004, 02:03:48 AM »
My 90 Tracker has an occasional leak there, too. Just crank the nuts down and that should seat the pipes together. From what I recal, there is no actual separate gasket or donut at that junction, just a tension fit...
