Free Downloadable FSM (Factory Service Manuals), USR (User Created Documents), O
  • 30628 Views
ebewley and 16 Guests are viewing this topic.
  • 6586
  • 66
TECH LIBRARY – FREE DOWNLOADS
RESEARCH – Downloadable documents for your Suzuki
FSM (Factory Service Manuals), USR (User Created Documents), OWN (Owner’s Manual), TSB (Technical Service Bulletin), Sales Brochures, etc.. Files from all over the ‘net with credit given when known. Please contact us if you have a file you’d like to add that may help the Suzuki automotive community.
http://www2.zukiworld.com/tech-library-documentation-downloads-for-your-suzuki/
  • 6586
  • 66
Continually growing list!
   FSM - Samurai Fuel Injection Supplement Manual rhinoman 99501-83350-33E.pdf   158.2 MB
   FSM - Samurai Maintenance Manual 99500-83300-33E.pdf   266.4 MB
   FSM - Sidekick 1996 Air Conditioning.pdf   1.9 MB
   FSM - Sidekick Vitara Service Manual rhinoman 99500-60A10-01E.pdf   27.7 MB
   FSM - Swift Electrical Component Locator 1.3L TBI.pdf   68.1 KB
   FSM - Swift GT ECM Electrical.pdf   171.5 KB
   FSM - Swift GT G13B Cam Timing.pdf   63.6 KB
   FSM - Swift GT G13B TPS Adjustment.pdf   120.9 KB
   FSM - Swift GT ISC Solenoid Valve.pdf   85.4 KB
   FSM - Swift GT Ignition System.pdf   20.9 KB
   FSM - Swift GT Junction Fuse Block.pdf   81.2 KB
   FSM - Swift GT Manual Transmission Schematic.pdf   221.5 KB
   FSM - Swift Supplimental Four-Wheel Drive 99501-71C00-01E.pdf   15.5 MB
   FSM - Vitara 1999-2005 Chassis Electrical Body Manual .pdf   20.2 MB
   FSM - Vitara 1999-2005 Engine Drivetrain Manual.pdf   8.0 MB
   FSM - Vitara 1999-2005 Full Service Manual.pdf   12.1 MB
   FSM - Vitara 1999-2005 Service Manual Canvas Top Supplemental.pdf   1.9 MB
   FSM - Vitara 1999-2005 Transmission Transfer Case Differential Manual .pdf   6.0 MB
   OWN - Tracker Owners Manual 1998.pdf   20.4 MB
   TSB - AC Compresor Refrigerant Oil Checking.pdf   48.1 KB
   TSB - AC Compresor Servicing.pdf   68.9 KB
   TSB - AC Compresor and Magnetic Clutch Assembly.pdf   505.7 KB
   TSB - AC System General Servicing.pdf   85.4 KB
   TSB - AC System Specifications.pdf   46.0 KB
   TSB - AT Transmission Controler Change Bulletin.pdf   69.6 KB
   TSB - Alternators and Regulators.pdf   116.6 KB
   TSB - Battery Maintenance.pdf   71.1 KB
   TSB - Brake System.pdf   114.2 KB
   TSB - Clutch and Compresor Asembly.pdf   69.0 KB
   TSB - Drive Axles.pdf   99.0 KB
   TSB - Engine 1.6L Diagnostics.pdf   258.1 KB
   TSB - Engine Cooling.pdf   82.3 KB
   TSB - Fuses and Circuit Breakers.pdf   55.2 KB
   TSB - High Tension Wire Bulletin.pdf   58.3 KB
   TSB - Hood Fly-Up Bulletin.pdf   121.9 KB
   TSB - Idle Adjust.pdf   158.8 KB
   TSB - Idle Speed-Isc Duty Adjustement.pdf   63.4 KB
   TSB - Instrument Panel.pdf   108.0 KB
   TSB - Modification Of The ECM Module.pdf   65.8 KB
   TSB - Starter.pdf   152.8 KB
   TSB - Swift G13B Engine Adjustments.pdf   158.8 KB
   TSB - Swift GT General Specs 1 of 2.pdf   62.9 KB
   TSB - Swift GT General Specs 2 of 2.pdf   158.8 KB
   TSB - Swift GT Wiring Diagrams.pdf   600.4 KB
   TSB - Swift MK3 Instrument Panel Testing.pdf   108.0 KB
   TSB - Swift Wiring Diagrams.pdf   600.4 KB
   USR - Samurai Usefull Random Parts Catalog.pdf   887.3 KB
   USR - Sidekick Wiring Diagram and Instructions for 92-95 16v.pdf   3.5 MB
   USR - Sidekick Wiring Diagram for 91-95 TBI.pdf   80.4 KB
   USR - Sidekick Wiring Diagram for 92-95 16v OBD1.pdf   88.6 KB
   USR - Sidekick Wiring Diagram for 96-98 16v OBD2.pdf   97.2 KB
   USR - Swift GT Gauge Cluster Wiring.JPG   84.7 KB
Offline motofabio
  • 202
  • 6
  • 87 Samurai JX TinTop
Nothing in the tech library?
  • 6586
  • 66
Whoops! That looks broken...
I'll work on fixing that. In the meantime, go to our daughter site izook.com there are downloads there.
Offline rando guy not for sale
  • 10
Still don't see the files for downloading... Any updates on the "fix"?
  • 6586
  • 66
OK, we've finally made some traction on this... It is a work in progress but there are now files available to download in our 'Tech Library'. We will be adding more and updating descriptions and so on as time permits.
Thanks, Eric
  • 6586
  • 66
It's nice to have a whole list of downloadable FSM right here!  -Eric
