Rear cages for Trackicks
  • 28 Replies
  • 6854 Views
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
Re: Rear cages for Trackicks
« Reply #15 on: January 13, 2005, 01:51:49 AM »
I have been working on and planning to build a  full cage for several years now.
Wild,ppltrak, zukizzy  looks like we should have a roll cage building party. Who has space. I have a 3 stall garage of which 2 stalls are psudo shop.  I could host. I don't have a bender either but was considering one of those harbor freight jobbies.. Yeah I know cheap junk but I don't need a 5K dollar tube shark. I just need to bend some tube..
Does anyone have one of the Harbor Freight Tube benders?
Does it do the job or is it 100 bucks worth of crap?
I also saw that HF had tubing knotchers for like 40 bucks...May come in handy too.
mesjr2004 I like the way you hugged the windsheild on the inside. Looks Kick Ass
It is easier to get one rig build a cage then write down the specs. once you build one it is easy to build more if you follow your old plan and you can tweak what you don't like on the next one.
Wayne
Clearly a road
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #16 on: January 13, 2005, 02:44:54 AM »
Wayne I do have a very good friend who is a licenced electrition(sp) ;DIf you need help just call.
 Kevin
the_dude
« Reply #17 on: January 13, 2005, 06:20:14 AM »
Agreed first one is the toughest and anything after that just get's better.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #18 on: January 13, 2005, 06:37:54 AM »
Hey Dude, I've seen some of the bends from the H/F bender and you could do better with a torch and a tree. Don't waist your $. I have used one that wasn't hyd. but had different dies for different pipe. It worked great.
kevin
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #19 on: January 13, 2005, 07:51:50 AM »
There a difference between a tub bender and a pipe bender.
Harbor freight is a pipe bender (I think) it pushes up from the center and bends it.  It tends to crush the pipe.
A tub bender has a die that the tub is drawn into.  Kinda rolls the bend into it.  This is what is needed for the cages and why they cost so much.
96 Tracker
32 MTR's Warn 8000i
Offline mesjr2004
  • 422
« Reply #20 on: January 13, 2005, 10:36:22 AM »
i had a harbor freight bender it was junk for tube it does fine on sch 40 pipe thats it. and my cage does not interfear with top. ;)
Offline CuriousKid
  • 31
  • I'm Just Curiously Inquiring...
« Reply #21 on: January 13, 2005, 11:42:52 AM »
Nice setup.  What's the elastic netting for? Tying down loads?
« Reply #22 on: January 13, 2005, 11:19:10 PM »
Yea, I got the netting to hold a cooler  in place when riding. It was not strong enough to hold it still in the rough stuff, so I mooved the nett to the roof bar. It  works great.I keep that one where it is to hold my camping gear in when driving to/from the trail. and I have another one that hooks to the roll bar to keep all my junk from flying out while reail riding.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #23 on: January 14, 2005, 12:18:21 AM »
Well, all this has me prety excited!  Guess I'll look at extending my Calmini cage to the back, and putting two more "stringers" front-to-back over the front seat area.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Baloo
  • 84
  • I love YaBB 1G - SP1!
« Reply #24 on: January 14, 2005, 03:37:59 AM »
Wow guys thanks for the input, I have some ideas now.  ;D
the_dude
« Reply #25 on: January 16, 2005, 01:17:51 PM »
Posted by: mesjr2004 Posted on: Jan 12th, 2005, 6:49pm
i built this cage but i dont see why you couldnt do the same behind a calmini cage ,i didnt like the idea of bumping my head or nee every time i got in so i removed the dash and ran my tobes along the side of the body as close to the windshield frame as possable then used a 2'' holesaw to cut corner of dash out and put dash back in ,only took 6 hrs from start to finish.
I like how you kept the cage so tight to the windshield frame. Nice work, That's exactly what I want to do with my cage.  Was it difficult to get in place? The struggle I had on the first Geo I built was getting a decent front loop with all the bends to match up to the front geometry.
So if the harbor freight thing is junk. What are the other options?  Have you guys seen these deals?
this one you have to practice your fab skills first. Wonder how much you have to invest to build this thing?
Where do you get dies.. Seems like a hassle.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3867977367
Shady
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3867230665
Hanging out under the same Shade tree...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3866582103
Interesting. I think I am going to give these guys a call.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3867061278
This is the HF equivalent which =junk
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3866445723
« Reply #26 on: January 16, 2005, 01:33:44 PM »
That one you want to call on
is the same as Zukizzy has
Offline mesjr2004
  • 422
« Reply #27 on: January 16, 2005, 01:41:10 PM »
the bender i used was old, i borrowed it from a friend, the bender im gona buy is a m-teck . m-tecksuppily.com
it was verry tite between the kick pannel and wear the fusebox,and computer is mounted.i had to take all that stuff loose to get tobes in. but with anny mecanical skill it shouldnt be too hard.,
thanks for all the compliments guys,i try to do a good job on stuff but still a little self conscious about my work.
Offline zukizzy
  • 123
« Reply #28 on: January 17, 2005, 02:12:29 AM »
I use a JD2 (squared) model 3. it is a good quality bender at entry level prices and the hyd kit is easy to buy and install or just fab from parts. ;D I don't have hyd yet but soon. One reason I use this bender is that there are 3 in walking distance from my shop and we all share the odd dies. I own 1.25 1.5 and 1.75. but have access to 1" 1.625" and 2" within a block plus different radius in the sizes I own.
Pro tools has a similar one that you can buy from  rockbuggy supply in corona ca. they are so similar that it was a tossup between the 2 only my buddies haveing JD2 made the difference.
HTH
Wayne
Clearly a road
