Rear cages for Trackicks
  • 28 Replies
  • 6365 Views
Offline Baloo
  • 84
« on: January 12, 2005, 04:02:23 AM »
 ??? Hey does anyone have pictures and/or ideas on installing a rear cage to the Cal Mini front cage. I want to cover the rear seats but still be able to use the rag top and a hard top. I'm doing this to a 1990 Tracker. Any info would be helpful pictures are worth a thousand words. Cheers.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Rear cages for Trackicks
« Reply #1 on: January 12, 2005, 04:04:40 AM »
Hmm...
Don't know how well that would work.
As I see it, the top folds back into the exact place you'd want to anchor a rear roll bar.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: January 12, 2005, 04:16:36 AM »
Look at some of Hagen's black tracker. You could also remove the rear seatbelt horns and have some more room.
Kevin
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #3 on: January 12, 2005, 04:24:29 AM »
Even though I've removed the rear seat (for now), I would never remove the rear belts.  Yeah, the towers are in the way a bit, but if I put the seat back in, and have a rear passenger, they WILL be belted in!
Bob
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: January 12, 2005, 04:28:07 AM »
I meant to remove the towers and then after the cage bolt the uppermount to the cage :-/ just to give more
room for base plates
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
« Reply #5 on: January 12, 2005, 07:29:48 AM »
Ive never done one but I could and let ya know. anyone near socal need a rear cage ;D?
Wild???
Anyone
Thanks
Wayne
Clearly a road
« Reply #6 on: January 12, 2005, 09:02:08 AM »
Am I going to have to change my
name from Wild to  Guinea Pig   ;)
I suppose I could pose for a rear roll cage
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #7 on: January 12, 2005, 12:39:33 PM »
Hey Wayne, I need one. I can weld and fab. I just dont have a bender. Now that it stopped raining, have you fixed the elec.?
see ya,
Kevin
Offline mesjr2004
  • 422
« Reply #8 on: January 12, 2005, 12:49:41 PM »
i built this cage but i dont see why you couldnt do the same behind a calmini cage ,i didnt like the idea of bumping my head or nee every time i got in so i removed the dash and ran my tobes along the side of the body as close to the windshield frame as possable then used a 2'' holesaw to cut corner of dash out and put dash back in ,only took 6 hrs from start to finish.
« Reply #9 on: January 12, 2005, 01:44:33 PM »
Looks pretty good there Mr mesjr2004 ;D
the_dude
« Reply #10 on: January 12, 2005, 04:44:30 PM »
I have been working on and planning to build a  full cage for several years now.
Wild,ppltrak, zukizzy  looks like we should have a roll cage building party. Who has space. I have a 3 stall garage of which 2 stalls are psudo shop.  I could host. I don't have a bender either but was considering one of those harbor freight jobbies.. Yeah I know cheap junk but I don't need a 5K dollar tube shark. I just need to bend some tube..
Does anyone have one of the Harbor Freight Tube benders?
Does it do the job or is it 100 bucks worth of crap?
I also saw that HF had tubing knotchers for like 40 bucks...May come in handy too.
mesjr2004 I like the way you hugged the windsheild on the inside. Looks Kick Ass
« Reply #11 on: January 12, 2005, 05:23:51 PM »
Zukizzy has a little 4000 Sq Ft
shop with all the tubing goodies
and a 2 pole lift, my kind of playground
See the "Wild Doors" post, that's in the shop
« Reply #12 on: January 12, 2005, 10:53:28 PM »
You can still fully use the tops with this set up. Though I have removed my back seat to haul my camping gear you can still fully access the rear by side or rear door and still use the rear seat (with belts). I also opted for the Kick it when you get in lay out in the front. If I did it over I would definately take the front hoop through the dash to get it out of the way, but it is not to bad once you get use to it.
I am getting rid of rear passenger all together to I will make a few changes to the cage before long (cross bars behind seats for harness mounts for one.
HTH,
Offline explosivo
  • 3157
« Reply #13 on: January 12, 2005, 10:59:12 PM »
It bends thick tube fine, but I'd be scared bending material thinner than 1/8".
« Last Edit: January 12, 2005, 11:00:02 PM by explosivo »
omghi2.us[/url]
Offline zukizzy
  • 123
« Reply #14 on: January 13, 2005, 01:49:08 AM »
see ya,
Kevin
Not yet this work thing is cramping my play style. Sat I think at least a temp(read above ground) fix ;D
Thanks
Wayne
Clearly a road
