front main leaking oil on sammi 1.3
samurai dan
February 18, 2008, 06:55:46 PM »
has any body heard of a reddi sleeve or a speedi sleeve to help seal front main oil seal and if so who might sell them. I know my 1.3 has lots of miles left and i dont want to tear the engine down to fix it....appreciate any help here
Thanks,
Dan
daddyizzle
728
Colorado is still my home!!
Re: front main leaking oil on sammi 1.3
February 19, 2008, 02:32:35 PM »
I've heard that if you score hole where that seal goes in or the shaft, you could have leaks there that are hard to fix. I also heard you could put a bushing in there if you score the hole and go with a smaller seal maybe. Is your seal bad or is the hole scored or the crank scored. Why don't you just do a t belt job and replace the seal? I guess the seal for the oil pump could be leaking. I just snugged mine up since it looked like it might have been leaking. I haven't seen any oil leaks since I changed the seals and snugged the oil pump bolts. It's not too hard of a job.
-Adam
If all criminals were behind bars, there would be no one left to patrol the streets.
86 Samurai Tin-Top stock with a Harley 44 sidedraft carb
