front main leaking oil on sammi 1.3
  • 1517 Views
samurai dan
« on: February 18, 2008, 06:55:46 PM »
has any body heard of a reddi sleeve or a speedi sleeve to help seal front main oil seal and if so who might sell them. I know my 1.3 has lots of miles left and i dont want to tear the engine down to fix it....appreciate any help here
Thanks,
Dan
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: front main leaking oil on sammi 1.3
« Reply #1 on: February 19, 2008, 02:32:35 PM »
I've heard that if you score hole where that seal goes in or the shaft, you could have leaks there that are hard to fix. I also heard you could put a bushing in there if you score the hole and go with a smaller seal maybe. Is your seal bad or is the hole scored or the crank scored. Why don't you just do a t belt job and replace the seal? I guess the seal for the oil pump could be leaking. I just snugged mine up since it looked like it might have been leaking. I haven't seen any oil leaks since I changed the seals and snugged the oil pump bolts.  It's not too hard of a job.
-Adam ;D
