what kind of fluid do you put in the manual tranny on a tracker?
wibornz
55
5 atvs and now a tracker
May 19, 2008, 05:10:54 PM »
Need to change mine thanks
jeff1997
1228
27
Suzuki: A Jeep thing only cheaper!!!!
Re: what kind of fluid do you put in the manual tranny on a tracker?
May 19, 2008, 05:20:29 PM »
Check the manual, but I used 90w gear lube and Lucas additive. the maual should tell you exactly what kind and how much to use.
2" coil spacers- I make and sell 1.5" and 2" on e-bay. Look under seller: hoepkers
3" Masterkit1 body lift
Custom strut spacers
Trackin_Tracker33
137
Have Gun will travel
May 19, 2008, 05:20:48 PM »
Royal Purple.... expensive but worth it
I got your Jeep thang, thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS, SAS'N it
rascott
669
15
tread lightly monkeywrench a little
Reply #3 on:
May 19, 2008, 06:21:42 PM »
temperature dependent, also
KickTurn
53
My wife likes the smell of petroleum products.
Reply #4 on:
May 20, 2008, 10:42:28 AM »
It's probably worth making certain that you are putting in GL-4. The alternative, GL-5, may cause premature wear on yellow metal components in your synchros, etc. Synthetic, like Royal Purple or others is a good idea, but expensive of course.
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
MaD.72
183
It's not what you buy, it's what you built!!!
Reply #5 on:
May 20, 2008, 11:11:26 AM »
This is from the manual:
Gear oil API GL-5 SAE 75W-90 and it need almost 2 liter...
