what kind of fluid do you put in the manual tranny on a tracker?
  • 1850 Views
Offline wibornz
  • 55
  • 5 atvs and now a tracker
Need to change mine thanks
Offline jeff1997
  • 1228
  • 27
Re: what kind of fluid do you put in the manual tranny on a tracker?
« Reply #1 on: May 19, 2008, 05:20:29 PM »
Check the manual, but I used 90w gear lube and Lucas additive. the maual should tell you exactly what kind and how much to use.
3" Masterkit1 body lift
Custom strut spacers
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
« Reply #2 on: May 19, 2008, 05:20:48 PM »
Royal Purple.... expensive but worth it
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
Offline rascott
  • 669
  • 15
« Reply #3 on: May 19, 2008, 06:21:42 PM »
temperature dependent, also
Offline KickTurn
  • 53
  • My wife likes the smell of petroleum products.
« Reply #4 on: May 20, 2008, 10:42:28 AM »
It's probably worth making certain that you are putting in GL-4.  The alternative, GL-5, may cause premature wear on yellow metal components in your synchros, etc.  Synthetic, like Royal Purple or others is a good idea, but expensive of course.
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
« Reply #5 on: May 20, 2008, 11:11:26 AM »
This is from the manual:
Gear oil API GL-5 SAE 75W-90 and it need almost 2 liter...
