Christmas Present for myself ;-)
  • 36 Replies
  • 7847 Views
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
Re: Christmas Present for myself ;-)
« Reply #30 on: December 27, 2004, 05:53:35 PM »
It's a SideKick, and you need more than
a bigger fuel fump. Are you going  to keep
the carb ?
If you are I don't think you need an adjustable
fuel pressure regulator, unless you got a high
pressure pump, then with a carb you would have
too much pressure, you need about 3-5 PSI to
keep up.
Ah Sidekick or Vitara as they are called overhere ! Well, engine is the same as I am going to use I guess ? I am keeping the 32/36 Weber for now as the setup is complete like this ( maybe upgrading to a 38/38 in the future ). You think ( or know  ;) ) the standard fuelpump should be sufficient ? I know about the fuelpressure regulator, setting it on 2 psi for offroaduse and 3psi for onroaduse. The fuelpump I'm getting is sufficient enough for J|removethispart|@|removethispart|@ps so maybe too big for the Sammi?
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
« Reply #31 on: December 27, 2004, 06:03:34 PM »
Jeep pump for a carb should be fine
I didn't know you were in NL
;D
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #32 on: December 27, 2004, 06:54:03 PM »
;D
Friend of mine |removethispart|@ www.offroadcentre.nl just called me and he can get me a 4 to 5 psi fuelpump ( for a Jeep ) and an automatic fuelpressureregulator, which regulates itself to 0.5 psi at idle and up to whatever is needed on- or offroad. Good idea ?
I'll get the specs this afternoon, maybe even a piccie of the regulator.
And yes, I'm from the ( at the moment very snowy ) Netherlands
« Last Edit: December 27, 2004, 06:54:32 PM by nitromax »
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #33 on: December 30, 2004, 07:29:16 PM »
Suzi's Place ordered an oilfilteradaptor from which I can mount the oilcooler, it goes inbetween the engine and the oilfilter. I'm picking up the( secondhand, but almost new ) oilcooler next Friday, make the brackets for it and have a forklift company nearby make me the special hoses and connectors.
« Reply #34 on: December 31, 2004, 03:20:10 PM »
Sweeeeeeeeeeeeeeeet ;D
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #35 on: December 31, 2004, 11:03:06 PM »
sorry if this seems like a hi-jack, but is there much difference in the weber 32/36 and the weber 38/38?
i see a lot of set ups using the 32/36 weber for forced induction, what about the 38/38?
is the 38/38 good with out being forced induced?
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #36 on: January 01, 2005, 01:24:32 AM »
Sarge, the man from MidWest Performance is the one to answer all you Weber questions. He told me to get a 38/38 carb for this set-up, it would even be faster that way. Since this set-up is ready to go on a Samurai ( it was on a 1600, which I am going to install soon ) I thought I'd keep it this way untill I have tried it ( and untill I can find a 38/38 for a good price  ;) )
Difference - besides size of course -   is the fact that on the 32/36 the throttle opens one at the time and on the 38/38 they open both at the same time.
Sarge will correct me if I'm wrong  ;)
