Forum Changes!
  • 2888 Views
  • 6601
  • 68
Forum Changes!
« on: May 19, 2018, 09:04:26 AM »
Hello All - In order to secure the webserver (https) it was necessary to change the theme and a few other settings. What you're seeing looks good to us but if you see something amiss or something is missing please PM me or reply to this post so we can solve it.
Thank you, Eric
  • 6601
  • 68
Re: Forum Changes!
« Reply #1 on: May 26, 2018, 10:06:09 AM »
I found a new cool feature. Quick reply box at the bottom. Thinking abiut moving it to t th e top to encourage use. Would people use it? Are people using it?
Eric
Re: Forum Changes!
« Reply #2 on: May 26, 2018, 01:15:52 PM »
A quick reply box?
I don't see a quick reply box - which I think of as a space that I can immediately start typing a reply.
What I am seeing, and I think is not how it should be, is a lot of wasted white space - the text of each post is below the poster details, rather than to the right of it - I can send you a screen capture if this is not what you're seeing.
Re: Forum Changes!
« Reply #3 on: May 26, 2018, 03:11:17 PM »
I see both the Reply button at the top, and the Quick Reply at the bottom.  It will take a little to figure out how I like the actions now.  I did like that I could click on Unread at the top and get all sections of unread replies in the old form.
« Last Edit: May 26, 2018, 03:15:24 PM by BRD HNTR »
Offline fuzzy1
  • 350
Re: Forum Changes!
« Reply #4 on: May 27, 2018, 09:20:29 AM »
I think the new layout looks GREAT overall! I also see what Fordem mentioned with the text being below the user info rather than beside it, but only when it's windowed. If I maximize the window the text appears beside user info/avatar. Maybe a word wrap setting can be changed?
The other thing I notice is that if I'm not logged in, the newest post appears on top, so the OP is at the end. When I'm logged in it reverses to oldest (OP) first & replies after.
Non Illegitimi Conterat
Offline rasmeidirtrider
  • 76
Re: Forum Changes!
« Reply #5 on: May 28, 2018, 12:27:31 AM »
The change makes it difficult to follow the development of the thread. For example page 1 becomes page 5?
https://www.zukiworld.com/forum/build-diaries-how-to-diy/sidekick-sport-build-2/msg296729/#new
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4 auto, 4x4, 4dr, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R/16.
  • 6601
  • 68
Re: Forum Changes!
« Reply #6 on: June 10, 2018, 08:40:44 PM »
Still tweaking here and there... Adverts should be less intrusive now... and I think I've got the Avatars to function correctly. How does those two things look?
Thanks, Eric
