Wiring - help
  • 2096 Views
Offline vitara-dave
  • 11
  • I love YaBB 1G - SP1!
Wiring - help
« on: November 13, 2006, 08:47:30 AM »
I had to put in a new gasket in my engine (1600 16V) and know i've refitted everything. The problem is that i don't what to do with 1 plug of the wiring from the injection. It is a white plug at the end of the wiring loom, ends at the same place as the throttle position sensor. Can you help me? (If needed, i will try to show a picture.)
Re: Wiring - help
« Reply #1 on: November 13, 2006, 10:41:22 AM »
That would be for the injector, there should be a matching plug round the back of the throttle body.
Offline vitara-dave
  • 11
Re: Wiring - help
« Reply #2 on: November 14, 2006, 12:19:57 PM »
Ive multipoint injection and all 4 injectors are connected. Ore is there more?
« Last Edit: November 14, 2006, 12:21:44 PM by vitara-dave »
Offline vitara-dave
  • 11
Re: Wiring - help
« Reply #3 on: November 16, 2006, 03:25:17 AM »
Can nobody help me?  :(
(The Vitara has to work this weekend...)
Offline mrfuelish
  • 2862
Re: Wiring - help
« Reply #4 on: November 16, 2006, 10:25:41 PM »
mine has one there like that also, I think it is for the california e.g.r. valve.
Offline Uncivilized
  • 1469
    • Car Domain
Re: Wiring - help
« Reply #5 on: November 17, 2006, 05:30:46 AM »
I checked my 95 canadian model, I traced the wires to something mounted to the back on the engine, looks similar to the EGR valve in a vertical position. It's very close to the heater core hoses entering the firewall, right above them.
