Wiring - help
Wiring - help
vitara-dave
11
I love YaBB 1G - SP1!
Wiring - help
November 13, 2006, 08:47:30 AM »
I had to put in a new gasket in my engine (1600 16V) and know i've refitted everything. The problem is that i don't what to do with 1 plug of the wiring from the injection. It is a white plug at the end of the wiring loom, ends at the same place as the throttle position sensor. Can you help me? (If needed, i will try to show a picture.)
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: Wiring - help
November 13, 2006, 10:41:22 AM »
That would be for the injector, there should be a matching plug round the back of the throttle body.
http://www.rhinopower.org
vitara-dave
11
Re: Wiring - help
November 14, 2006, 12:19:57 PM »
Ive multipoint injection and all 4 injectors are connected. Ore is there more?
Last Edit: November 14, 2006, 12:21:44 PM by vitara-dave
vitara-dave
11
Re: Wiring - help
Reply #3 on:
November 16, 2006, 03:25:17 AM »
Can nobody help me?
(The Vitara has to work this weekend...)
mrfuelish
2862
13
you must have a perception problem.
Re: Wiring - help
Reply #4 on:
November 16, 2006, 10:25:41 PM »
mine has one there like that also, I think it is for the california e.g.r. valve.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
Uncivilized
1469
Re: Wiring - help
Reply #5 on:
November 17, 2006, 05:30:46 AM »
I checked my 95 canadian model, I traced the wires to something mounted to the back on the engine, looks similar to the EGR valve in a vertical position. It's very close to the heater core hoses entering the firewall, right above them.
