29 mpg!!!
  • 12 Replies
  • 2888 Views
Offline urbanwheeler
  • 696
29 mpg!!!
« on: May 21, 2006, 12:57:44 AM »
Today I got 29.38 mpg while on a trip ;D. That is better than the epa mileage estimate of 28 highway. I usually get about 27, and 26 while driving around town. I have the timing set at 10 degrees BTDC, am running 215/75r15 tires, and run the a/c quite a bit. I am quite amazed that it gets the mileage it does ;D.
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
Re: 29 mpg!!!
« Reply #1 on: May 25, 2006, 11:35:09 AM »
Eighty some views and no replies...  29 mpg is pretty good.  You obviously don't have a heavy foot.  I have found that with conservative driving habits it isn't hard to beat the EPA  estimates.
When I was shopping for a replacement for my Toyota last summer, I wanted high mpg, top reliability and mountain goat surefootedness.  I figured 25 mpg was as good as I could expect.  My Sidekick Sport has beat that mileage significantly and meets the other criteria.  These are great little vehicles.
Offline Yoak
  • 577
Re: 29 mpg!!!
« Reply #2 on: May 25, 2006, 11:42:15 AM »
That's awesome what year is it? 8v/16v?
Offline the_maplebar
  • 466
Re: 29 mpg!!!
« Reply #3 on: May 25, 2006, 11:44:42 AM »
all sport models would be 16 valve right?
Offline Maroon Monsoon
  • 876
Re: 29 mpg!!!
« Reply #4 on: May 25, 2006, 11:51:24 AM »
yea, I hardly ever run my ac but with my 2.5 litre that's rated for about 19 in town and 21 on highway gets 23 miles a gallon in town and I romp on it at times.. got to keep the carbon build up out you know
zuk's get good mileage
Offline Yoak
  • 577
Re: 29 mpg!!!
« Reply #5 on: May 25, 2006, 11:57:50 AM »
oopppps...
you right should be 16v...
sill waking up  ::)
Re: 29 mpg!!!
« Reply #6 on: May 25, 2006, 11:59:04 AM »
His signature says "an unmodified 8valve TBI motor"
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: 29 mpg!!!
« Reply #7 on: May 25, 2006, 12:00:43 PM »
my 95 2-door tracker stock with 8V has gotten 33-34mpg before, depending what terrain i'm driving it in.  It gets 28mpg all week long back and forth to work.  My red 4-door 16V recently improved from 23mpg to 25mpg perhaps due to a temp increase in the weather, or less humidity in the air?  I haven't changed a thing on it and the mpg has been going up and up.
1993 4-door Sidekick
4.24:1 t-case
Re: 29 mpg!!!
« Reply #8 on: May 25, 2006, 12:03:52 PM »
Can't wait to get the 1.6L with the 1.3L head in my Samurai - I bet the lighter weight / smaller valves will be a killer gas mileage combo!
~J~
Offline Yoak
  • 577
Re: 29 mpg!!!
« Reply #9 on: May 25, 2006, 12:10:52 PM »
I am reading and responding from a phone...so I cannot  always see sigs
Offline rottyfan
  • 15
  • I love YaBB 1G - SP1!
Re: 29 mpg!!!
« Reply #10 on: May 29, 2006, 10:53:46 AM »
Our Tracker consistently gets 19-20 mpg just driving about 5 miles each day to and from the train station.  This is actually pretty good since short trips usually get the worst gas mileage.  Last week I drove from Connecticut to New Jersey to pick up an air compressor and I got 26 mpg over a 232 mile stretch.  Mind you I was driving mostly 70-80 most of the way and on quite a few stretches 80-85 if the traffic permitted.  It was pretty warm and had the AC blasting the whole time.
Annoy a Liberal:
Work, Succeed, Be Happy
Offline takai
  • 907
Re: 29 mpg!!!
« Reply #11 on: May 29, 2006, 11:03:06 AM »
~J~
Watch your tuning closely. My friend has had a horrible time getting his weber tuned right for that configuration.
'Cause, I am to misbehave.
Re: 29 mpg!!!
« Reply #12 on: May 29, 2006, 01:37:27 PM »
I'm not a big fan of the webbers actually. I was hoping I could keep the stock carb. I was originally going to go to fuel injected, but more and more, I think I want to keep the stock 1.3L head (my machineist buddy and I think it'll be better for low end torque / response).
~J~
