How hard is it to install t-case gears?
whitestanger
18
April 14, 2009, 12:18:22 PM »
Just bought a set of 6.5-1 t-case gears for my samurai from low range and was wandering if anybody has installed them before and how hard is it. I was wandering if I will need a press to a get the bearings and gears apart?
1988 1/2 Samurai
6" breeze Industries SPOA lift & trac bar
4" Body Lift
33"x13.50" Super Swampers on off set 15" rims
5"-10" drop shackles front and rear
Skyjacker Shocks
Russel stainless steel brake and fuel lines
Fuel cell
10 000 winch front
3000 winch rear
custom bumpers
Drone637
8121
116
Evil Cow
Re: How hard is it to install t-case gears?
April 14, 2009, 12:50:59 PM »
They help, but they are not required. I did it in the garage over the course of a couple of hours. You will need to grind out the inside of the t-case though to make room for the larger gears.
If you do a search you should be able to find a couple of write-ups. There are also installation walk-thru available at
http://zukiworld.com/month_070102/feature_rockrawlerdl_install.htm
