I need help
I need help
brace
264
I built it; I break it; I fix it.
I need help
September 10, 2004, 04:35:24 AM »
My 87 tintop is not acting right. It won't maintain speed or level out without constantly gunning the gas.
A mechanic told me it might be a clogged cat. I replaced the plug wires and sprayed some wd-40 in the distributor cap hoping that it was moisture. It just seems like it is not getting gas but it can get up to speed.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
trackermad
150
Re: I need help
September 10, 2004, 04:40:25 AM »
I mention this only because I just had a similar problem but are your breaks getting hot?
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so." ~Bertrand Russell
Mike71
1449
Re: I need help
September 10, 2004, 06:27:43 AM »
sounds like either a cat..or a spark plug
mine had those same symptoms when 2 of my spark pplugs worked themselfs loose
623hp kb cobra sold! 100hp kick new DD
wildgoody
8134
67
Re: I need help
Reply #3 on:
September 10, 2004, 06:31:31 AM »
Crap in the Carb could block the jets,
then pushing the throttle adds fuel and
power, for a moment
Just a thought
azrocktrash
121
Re: I need help
Reply #4 on:
September 10, 2004, 07:49:11 AM »
pluged cat or fuel filter.
 oscar
Last Edit: September 10, 2004, 07:50:00 AM by azrocktrash
87 zuk,84 sj410 4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
~Life begins,where the pavement ends~
jerryp58
449
Re: I need help
Reply #5 on:
September 10, 2004, 09:11:02 AM »
Is this carb or FI?
Fuel pump?
Fuel pressure regulator (if FI)?
Jerry
1990 Geo Tracker, 2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
brace
264
Re: I need help
Reply #6 on:
September 11, 2004, 06:12:07 AM »
its carb and those suggestions will be all looked into. Thanks, Brace
