I need help
  • 2372 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
I need help
« on: September 10, 2004, 04:35:24 AM »
My 87 tintop is not acting right.  It won't maintain speed or level out without constantly gunning the gas.
A mechanic told me it might be a clogged cat.  I replaced the plug wires and sprayed some wd-40 in the distributor cap hoping that it was moisture.  It just seems like it is not getting gas but it can get up to speed.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline trackermad
  • 150
Re: I need help
« Reply #1 on: September 10, 2004, 04:40:25 AM »
I mention this only because I just had a similar problem but are your breaks getting hot?
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline Mike71
  • 1449
Re: I need help
« Reply #2 on: September 10, 2004, 06:27:43 AM »
sounds like either a cat..or a spark plug
mine had those same symptoms when 2 of my spark pplugs worked themselfs loose
Re: I need help
« Reply #3 on: September 10, 2004, 06:31:31 AM »
Crap in the Carb could block the jets,
then pushing the throttle adds fuel and
power, for a moment
Just a thought
Offline azrocktrash
  • 121
Re: I need help
« Reply #4 on: September 10, 2004, 07:49:11 AM »
pluged cat or fuel filter.
 oscar
« Last Edit: September 10, 2004, 07:50:00 AM by azrocktrash »
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
Offline jerryp58
  • 449
Re: I need help
« Reply #5 on: September 10, 2004, 09:11:02 AM »
Is this carb or FI?
Fuel pump?
Fuel pressure regulator (if FI)?
Jerry
Offline brace
  • 264
Re: I need help
« Reply #6 on: September 11, 2004, 06:12:07 AM »
its carb and those suggestions will be all looked into.  Thanks, Brace
