Is there an adjustment on clutch switch?
jzap
515
2
How difficult can it be?
March 03, 2005, 03:47:28 AM »
i have a 96 tracker. Lately I have to really stomp on the clutch to get it to let the starter engage.  Where is the starter lockout switch located, and is there an adjustment that I can make, or can you just put a jumper across it without burning something up?
Last Edit: March 03, 2005, 03:48:52 AM by jzap
Jim Z.
96 Tracker
66 Apache camper
Blasted
63
Yea.. its a Kick.. Keep dreamin.
Re: Is there an adjustment on clutch switch?
March 03, 2005, 07:47:16 AM »
Give it a check for dust bunnies.... sounds simple enough. Mine actually quit working because of how dirty is was. There is a way to test it, it specifies how to in the hayes manual.
93 Sidekick 2Dr. 2"body lift. 30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack. Custom ground High torque Cam shaft. And CB for talkin trash.
shilly
March 03, 2005, 09:31:50 AM »
Mine does the same, and I'm planning on rerouting the wires and using them for a kill switch up under the dash somewhere. I had a look under there and I'm lacking the double rear-articulated elbow to try and adjust the blasted thing. Just my .02
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Reply #3 on:
March 03, 2005, 01:51:25 PM »
SPLICE THE WIRES TOGETHER AND BYPASS THE SWITCH.
IN COMES IN HANDY TO RESTART IN GEAR IN LOW RANGE. I JUST DON'T LET ANYONE ELSE DRIVE IT FOR SAFETY SAKE
ROSS
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
jzap
515
2
Reply #4 on:
March 04, 2005, 10:16:26 AM »
I finally took the time to crawl underneath the dash.
Turned out to be reeeeal simple. The switch is mounted on a threaded stem. Disconnect wires, loosen jam nut (14mm) twist the switch a turn or so, tighten jam nut, plug it in...
Jim Z.
96 Tracker
66 Apache camper
