Is there an adjustment on clutch switch?
  • 2043 Views
Offline jzap
  • 515
  • How difficult can it be?
« on: March 03, 2005, 03:47:28 AM »
 i have a 96 tracker.  Lately I have to really stomp on the clutch to get it to let the starter engage.  Where is the starter lockout switch located, and is there an adjustment that I can make, or can you just put a jumper across it without burning something up?
« Last Edit: March 03, 2005, 03:48:52 AM by jzap »
Jim Z.
66 Apache camper
Offline Blasted
  • 63
  • Yea.. its a Kick.. Keep dreamin.
Re: Is there an adjustment on clutch switch?
« Reply #1 on: March 03, 2005, 07:47:16 AM »
Give it a check for dust bunnies....  sounds simple enough. Mine actually quit working because of how dirty is was.  There is a way to test it, it specifies how to in the hayes manual.
93 Sidekick 2Dr.  2"body lift.  30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack.  Custom ground High torque Cam shaft. And CB for talkin trash.
shilly
« Reply #2 on: March 03, 2005, 09:31:50 AM »
Mine does the same, and I'm planning on rerouting the wires and using them for a kill switch up under the dash somewhere. I had a look under there and I'm lacking the double rear-articulated elbow to try and adjust the blasted thing.  Just my .02   ::)
Offline ROSS
  • 1412
« Reply #3 on: March 03, 2005, 01:51:25 PM »
SPLICE THE WIRES TOGETHER AND BYPASS THE SWITCH.
IN COMES IN HANDY TO RESTART IN GEAR IN LOW RANGE. I JUST DON'T LET ANYONE ELSE DRIVE IT FOR SAFETY SAKE
                                                 ROSS
Offline jzap
  • 515
« Reply #4 on: March 04, 2005, 10:16:26 AM »
I finally took the time to crawl underneath the dash.
Turned out to be reeeeal simple.  The switch is mounted on a threaded stem.  Disconnect wires, loosen jam nut (14mm) twist the switch a turn or so, tighten jam nut, plug it in...
Jim Z.
66 Apache camper
