wrong oil pump ??
  • 1 Replies
  • 1520 Views
Offline stosh22
  • 16
wrong oil pump ??
« on: March 18, 2007, 06:50:45 PM »
I ordered an oil pump on ebay and finally got a chance to put it into my 1992 Suzuki Sidekick 1.6 8V
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=330094154152&rd=1&rd=1
I think it is the wrong one because the new one has about a 1" hole at the bottom of the pump right under the crank seal but the old one just has a little pin hole just behind the seal.
I would think if I put this one in, oil would be blowing all over the place because there isn't much of a seal between the block and timing belt.
Is this for an 16v or a 1.3 or something?
It also comes with 2 O-rings and a metal gasket.  I know 1 o-ring is for the dipstick but I am not 100%sure where the other one goes.  Also, are you supposed to just use a gasket seal on both sides of the metal gasket or how does that work?
Also, anyone ever do this without taking the oil pan off or do you have to drop the front carrier, then pull the pan off.  This seems like a lot of grief....wonder if I should do the water pump while this is all apart too.  I did the front seal and timing belt about 15k ago....
1992 Suzuki Sidekick 2dr 1.6l 8v, 3" Body Lift, 2.5" RRO Lift, 31 x 10.50 Pro Comp Mud Terrains mounted on 15 x 7 3" bs rims from RRO.  Thorley Header, K & N Filter.  Lifted Gas tank.
Offline mrfuelish
  • 2862
Re: wrong oil pump ??
« Reply #1 on: March 18, 2007, 09:29:38 PM »
The pump they sent you  is for a 1995 or newer with a crank sensor, just put a small plug in it if you can find one,maybe from an electrical place or section in home depot and put some loc-tite on it. not sure if it is for a 16 valve or not? what ya pay for it?
