Removing rear 3rd on Tracker
  • 31 Replies
  • 6250 Views
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Removing rear 3rd on Tracker
« Reply #30 on: May 06, 2006, 05:55:14 AM »
Yes for the front, no for the rear, unless you grab the carrier too...  the 5.62's have a 10 bolt ring gear, and  93 and up have a 12 bolt carrier.
« Reply #31 on: May 06, 2006, 09:29:45 AM »
I get the idea that's a whole other story with setting things up which I can post if it ever happens.
If you swap the R&Ps you will need to set up the clearances (backlash) in the diff and/or the pinion preload using a new crush sleeve. You might want to invest in an FSM if you're going to do that.
