Sidekick 8v Headers
  • 21 Replies
  • 5352 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Sidekick 8v Headers
« Reply #15 on: May 11, 2004, 03:59:43 AM »
Mike, the reason you have an extra o2 is because your 97 is OBD2 which moniters the cat. If you take the cat out you will get a check eng. light with A code p0420. But that won't effect eng. perf. The front o2 sensor gives the rich/lean command.
             Later,
                      Kevin
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: May 11, 2004, 04:02:07 AM »
I think I will just leave it alone. ::)
Mike
Offline Vit-A-Jim
  • 47
« Reply #17 on: May 11, 2004, 05:56:59 PM »
Yesterday I had a chat with calmini's tech dept. And I asked them about the legality of their headers.
They told me that the calmini header is not legal in California, because of the optical inspection.
And when I asked them if it affects the emissions of the car, they replied that it doesn't affect at all.
Road is... The boring part that joins two mud tracks.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #18 on: May 12, 2004, 01:36:06 PM »
Mike
OK SO WHO HERE BELEAVES THAT  ;D
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« Reply #19 on: May 12, 2004, 02:54:22 PM »
It is correct, the header is a Thorley header minus the carb warm up pipe, that would mount to the exhaust manifold, and will not pass C.A.R.B. without it. Take a look at the Thorley header and you will see what they are talking about.
Mac
Offline ksa421
  • 382
« Reply #20 on: May 12, 2004, 08:53:18 PM »
I have the Hawk header, i like it alot. It deffinetly gave a little more zip. Plus Hawk make them with 3 (i think) different coatings, so you can get the fancy racing ceramic stuff if ya want :D
Jacob
Offline chopper
  • 57
  • go where no man goes
« Reply #21 on: May 13, 2004, 11:14:22 AM »
i just finished installing the calmini header and i have to say throttle respones is improved quite a bit, man i have to say these little 1.6l engines just running off the header can be quite LOUD but i had to go for a rip with just the header HAHAHAHAHHAAH :o ;D :o
92'sas tracker 32" muds, oba, locked and loaded, 8274, toys
cardomain page http://www.cardomain.com/ride/553823
