MORE POWER!!!??
  • 65 Replies
  • 12567 Views
Offline explosivo
  • 3157
Re: MORE POWER!!!??
« Reply #15 on: December 08, 2004, 09:53:45 PM »
P.S.  Chebby parts are not allowed in the shop so a 4.3 is out.
4.3's aren't light by any means anyway :D
omghi2.us[/url]
Offline mbmarkyb
  • 461
    • UK Vitara
Re: MORE POWER!!!??
« Reply #16 on: December 09, 2004, 03:38:32 AM »
the short space of time i have had my 4.24 calmini gears i can approach anything at tick over and have loads of torgue in 1st or 2nd low and i cant see me needing another engine poor truck weighs around 2 ton already,
Markyb (UK)
UK Vitara JLX SE
Offline mesjr2004
  • 422
Re: MORE POWER!!!??
« Reply #17 on: December 09, 2004, 10:27:07 AM »
what about a vw vr6 engine? about 170horses a tun of tork and mite even fit older vw trans,wich would means  u could probaly adapt it to suzki. oh they only have one head,so their small,but 2.9 cc
Offline bandit86
  • 1641
  • elv8rguy
Re: MORE POWER!!!??
« Reply #18 on: December 10, 2004, 09:12:04 AM »
Caution, Honda engines rotate the opposite way form every other engine out there.  you'll have 5 speed in reverse and 1 forward... sounds like fun
Offline MUTANT_ZUK
  • 152
  • Its only one of a kind if you make it!
Re: MORE POWER!!!??
« Reply #19 on: December 10, 2004, 09:43:43 AM »
  Perkins or Thermo king diesel ! Lots o torque.Lots of custom parts,but one of a kind! ;D  M.Z.
Now thats stress relief 4X4!                  MUTANT ZUK
Offline bioniconion
  • 268
  • I love YaBB 1G - SP1!
Re: MORE POWER!!!??
« Reply #20 on: December 10, 2004, 09:49:14 AM »
well i guess the engine swap is out of my price league =\ which really does blow. but instead it gives me money for my lift and gears. maybe if someone were to design a kit for them to bring the parts together and install for 5k..i bet that'd be really popular  ;)
Offline SnoFalls
  • 1358
Re: MORE POWER!!!??
« Reply #21 on: December 10, 2004, 10:25:20 AM »
have you talked to brent at rail tough? What your after is what he does ... http://www.trailtough.com
I fully expect you'll see "packages" from those guys for kick/tracs (sammies have probably been the bread and butter for quite a while).
Re: MORE POWER!!!??
« Reply #22 on: December 10, 2004, 12:08:51 PM »
LOL, I didn't know that, what a riot, that
would have been a hoot to see somebodys
new rig and it goes backwards in 1st
Re: MORE POWER!!!??
« Reply #23 on: December 10, 2004, 12:14:55 PM »
Funny you should mention that   ;D
Coming from tha trucking industry, I
have been aquainted with these little
diesels for some time, and the thought
had crossed my mind to put one into
a Suzuki, after all they are Japaneese
and Korean engines. Of coarse it would
have a turbo and a tweeked fuel system
for more power, these little engines only
put out around 30 HP but they are very
high torque. Turbo would increase the
output by 20 to 30 HP  ;D
Offline 1bigtracker
  • 3409
Re: MORE POWER!!!??
« Reply #24 on: December 10, 2004, 12:25:50 PM »
and increase the weigh by how much?
stu
Re: MORE POWER!!!??
« Reply #25 on: December 10, 2004, 12:32:37 PM »
I don't know, but being a Diesel they
are all Cast Iron, as opposed to a aluminum
block and head with steel sleeves, but it
would get like 40 MPG which is a significant
increase of fuel efficiency, as well as Diesel
which is off of the smog rolls  ;D
I bet it would be twice the weight of a
stock engine, but this would allow the
3+3 to be more comfy on the butt   ;)
Offline 1bigtracker
  • 3409
Re: MORE POWER!!!??
« Reply #26 on: December 10, 2004, 12:36:55 PM »
I have a VW TURBO DIESEL SETTTING ON THE ENGINE STAND IN THE SHOP!  so Wild what do you think?  how high can yyou rev a diesel?
stu
Re: MORE POWER!!!??
« Reply #27 on: December 10, 2004, 12:43:03 PM »
Good question, I think the VWs are a high
speed engine, can probably hit 4000 RPM
but I don't know what the design spec for
a Yanmar  or a ThermoKing engine, I think
about 3000 or more tho depending on the
stroke of the crankshaft.
The big diesels like the one I drove, 12L
Cat C-12  are 2000 max, and work at 1200
to 1800 RPM  but these engines produce
400-475 HP and like 1200 Ft Lbs Torque  :o
And that my friend will move you and 80,000
down the road while getting 7 MPG.
Offline 1bigtracker
  • 3409
Re: MORE POWER!!!??
« Reply #28 on: December 10, 2004, 12:46:15 PM »
ok i guess the plans are still to drop that into a sammy.  i need somthing that can go 6000RPM and stay there.   so i saw some one put an old Rotory Mazda in a sammy on IZOOK.  Rotory's are high RPM engines right?
stu
Re: MORE POWER!!!??
« Reply #29 on: December 10, 2004, 12:50:09 PM »
Why 6000 RPM ???  Diesels don't need
to spin that fast to move you, that's why
you can drive 60 MPH at 1200 RPM in a
Semi Truck, you would have to regear the
trucklet to the RPM and torque range of the
new engine, low T-case and high (4.62s) diff
gears would be a good combo for that setup
