oil pressure/ boost gauge
sidekick101
128
best site on the net
January 19, 2007, 06:40:26 PM »
where is the hole on the enign to putan oil temp gauge and is there any need for a boost gauge on a stocker 1.6l 8V? if so where do you put that one
1993 sidekick JX, 2 dr, soft top, automatic,
1badzuk
96
Re: oil pressure/ boost gauge
January 19, 2007, 11:10:19 PM »
theres no need for a boost gauge unless its turbo
87 sammy 33's sometimes on 35s hole lot of extras 4 link arb lockers built tcase and tranny 1.6 dual weber carbs racing seats snorkle and so on.........ALOT MORE..........
Rhinoman
4502
36
Bend it, Break it, Fix it
January 20, 2007, 06:28:14 AM »
To fit an oil pressure gauge you normally remove the stock oil pressure switch and fit the oil pressure sensor instead. You can fit a T piece to allow both to be used. You may need an adapter, the stock switch is an M10x1 thread.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
