oil pressure/ boost gauge
  • 1631 Views
Offline sidekick101
  • 128
  • best site on the net
« on: January 19, 2007, 06:40:26 PM »
where is the hole on the enign to putan oil temp gauge and is there any need for a boost gauge on a stocker 1.6l 8V? if so where do you put that one
1993 sidekick JX, 2 dr, soft top, automatic,
Offline 1badzuk
  • 96
Re: oil pressure/ boost gauge
« Reply #1 on: January 19, 2007, 11:10:19 PM »
theres no need for a boost gauge unless its turbo
87 sammy 33's sometimes on 35s hole lot of extras 4 link arb lockers built tcase and tranny 1.6 dual weber carbs racing seats snorkle and so on.........ALOT MORE..........
« Reply #2 on: January 20, 2007, 06:28:14 AM »
To fit an oil pressure gauge you normally remove the stock oil pressure switch and fit the oil pressure sensor instead. You can fit a T piece to allow both to be used. You may need an adapter, the stock switch is an M10x1 thread.
