my fu$%^&ing cooling system
  • 1433 Views
Offline aumtracker
  • 22
  • the worm is the spice
« on: September 10, 2005, 11:32:36 AM »
i everone, yesterday my coolent gauge started acting weird the needle was dropping when i pushed the gas when i let up it came back up to temp could this be the temp sending unit or is somthing realy wrong   why would the gas pedle have any thing to do with the temp gauge                 please help               aumtracker                       by the way its a 92 tracker 4x4
Offline SnoFalls
  • 1358
Re: my fu$%^&ing cooling system
« Reply #1 on: September 10, 2005, 11:39:47 AM »
my guess ...
the throttle cable is strecthing the harness in a way that a ground wire is now becoming open. Worthwhile to check it, cause if the engine doesn't have good ground, it won't run well (or at all!).
Offline bus_driver
  • 479
« Reply #2 on: September 10, 2005, 11:41:50 AM »
yeah check the wiring
even if the unit is f'd it will not do that
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline aumtracker
  • 22
« Reply #3 on: September 10, 2005, 11:51:40 AM »
thanx guy i'll check it out in the shop tonight
« Reply #4 on: September 10, 2005, 02:13:25 PM »
Check the wiring to the sender too,
it's below the thermostat, and kind
of where it gets hit more.
