Timing issues
  • 2054 Views
Offline Suzuki1.8
  • 283
Timing issues
« on: April 27, 2011, 08:55:14 AM »
I have a 1993 Suzuki Sidekick 1.6 16v. So over the weekend in Moan showing up Overpriced jeeps My sidekick started acting funny around 2.5 to3 k rpm. I changed the fuel fliter thinking it was a not getting gas but it didn't change it. I finaly figured that it jumped timing. I had to run advanced to get it off the trail. I retimed it and it skiped two teeth. The timing belt tensor is the cheapest looking thing i have ever seen. Has anyone else had this issue taking these things of road were it is bumpy or is there a fix for this???
Re: Timing issues
« Reply #1 on: April 27, 2011, 08:57:31 AM »
Change your timing belt at the recommended service intervals
and you won't have any problems, unless there is another problem
Offline Suzuki1.8
  • 283
Re: Timing issues
« Reply #2 on: April 27, 2011, 09:05:50 AM »
Timing belt was changed 5k ago. the belt tensor does not seem like it hold the tension all that well with that small spring and thin aluminum plate
Re: Timing issues
« Reply #3 on: April 27, 2011, 09:12:09 AM »
The spring is not for tension, just a guide for setting the tensioner,
I have logged over 270,000 miles in my 89' Sidekick and never had
a belt skip a tooth, so I would guess the tensioner was set too loose
Offline Suzuki1.8
  • 283
Re: Timing issues
« Reply #4 on: April 27, 2011, 09:18:08 AM »
Do you ever put locktight on the bolt holding the tensioner tight??
Re: Timing issues
« Reply #5 on: April 27, 2011, 09:21:14 AM »
No, I just make sure it has the right torque so it stays tight
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Timing issues
« Reply #6 on: April 27, 2011, 12:04:09 PM »
In my experience, I have always replaced the tensioner, when I've replaced the timing belt.  The Gnewt has not had any problems.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
