Timing issues
Timing issues
Suzuki1.8
283
Tires so low looks like i'm riding on blades
Timing issues
April 27, 2011, 08:55:14 AM »
I have a 1993 Suzuki Sidekick 1.6 16v. So over the weekend in Moan showing up Overpriced jeeps My sidekick started acting funny around 2.5 to3 k rpm. I changed the fuel fliter thinking it was a not getting gas but it didn't change it. I finaly figured that it jumped timing. I had to run advanced to get it off the trail. I retimed it and it skiped two teeth. The timing belt tensor is the cheapest looking thing i have ever seen. Has anyone else had this issue taking these things of road were it is bumpy or is there a fix for this???
wildgoody
8134
67
Re: Timing issues
April 27, 2011, 08:57:31 AM »
Change your timing belt at the recommended service intervals
and you won't have any problems, unless there is another problem
Suzuki1.8
283
Re: Timing issues
April 27, 2011, 09:05:50 AM »
Timing belt was changed 5k ago. the belt tensor does not seem like it hold the tension all that well with that small spring and thin aluminum plate
wildgoody
8134
67
Re: Timing issues
Reply #3 on:
April 27, 2011, 09:12:09 AM »
The spring is not for tension, just a guide for setting the tensioner,
I have logged over 270,000 miles in my 89' Sidekick and never had
a belt skip a tooth, so I would guess the tensioner was set too loose
Suzuki1.8
283
Re: Timing issues
Reply #4 on:
April 27, 2011, 09:18:08 AM »
Do you ever put locktight on the bolt holding the tensioner tight??
wildgoody
8134
67
Re: Timing issues
Reply #5 on:
April 27, 2011, 09:21:14 AM »
No, I just make sure it has the right torque so it stays tight
Bobzooki
1754
2
Web Wheeler
Re: Timing issues
Reply #6 on:
April 27, 2011, 12:04:09 PM »
In my experience, I have always replaced the tensioner, when I've replaced the timing belt. The Gnewt has not had any problems.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
