Only starts with either? why
  • 65 Replies
  • 14401 Views
Re: Only starts with either? why
« Reply #60 on: September 23, 2004, 02:28:51 PM »
I have had problems with the whole ignition assembly on the steering wheel that caused crazy shit before so I think this could be a good possibility. Like currently if I hit my hazard lights or right blinker, my wipers turn on and run untill I turn the blinker off :P :-/ :P
HTH,
Hey Zig, that's a bad ground in the engine
compartment, try the little black wire on the
Pass Side, front by the washer bottle, it also
goes to the turn signal if you want to trace it.
This solved my wiper turn signal problem
Offline jerryp58
  • 449
« Reply #61 on: September 23, 2004, 10:16:09 PM »
Thanks for all the good tips.  ;) Im going wheelin this weekend and wont have time try any of these till probabally Monday or tuesday.
Seriosly thanks,
Mike
Are you taking the "troublesome Tracker"?  Maybe it just needs to have some sense knocked into it  ;D
Jerry
1990 Geo Tracker,  2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
« Reply #62 on: September 24, 2004, 12:52:16 AM »
;DTHANKS!!! That has been bugging the hell out of me ;D
Offline szabotage
  • 114
  • snaggletooth
« Reply #63 on: September 26, 2004, 10:45:30 AM »
here's a link to what sounds like the same problem,  turns out it was the temp. sensor
http://www.zookpower.ca/forums/showthread.php?t=1230
« Reply #64 on: October 05, 2004, 12:42:46 AM »
Mike,
Did you get it going? What ended up being wrong with it? We need an update?
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #65 on: October 05, 2004, 02:50:15 AM »
I havent had time yo go over and mess with it yet. :-[soon....
