Only starts with either? why
  • 65 Replies
  • 14274 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« on: September 14, 2004, 10:04:13 AM »
My sister just bought a 94 tracker for a steal. However it only starts with starting fluid. It cranks just fine but no fire. Once its running you can drive it all day.
???Any ideas?
We swapped ECMs and fuel pressure regulator. No luck.
Mike
Re: Only starts with either? why
« Reply #1 on: September 14, 2004, 10:26:44 AM »
Some trucks are like that,  have you
checked the compression ???  could be low
;)  :D  :)  ;D
  • 6598
  • 68
« Reply #2 on: September 14, 2004, 10:32:11 AM »
???Any ideas?
Mike
Make sure the fuel pump is running when the engine is cranking. There are two modes for turning on the fuel pump crank and run...
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #3 on: September 14, 2004, 10:34:53 AM »
;)  :D  :)  ;D
Naw, once its runnin it hauls ass. It just passed 100k. her other one with the 32s has almost passed 200k...it starts great. Go figure :P
Its definately not gettin fuel on startup. We have a donor vehicle to swap parts back and forth but which parts?
Mike
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: September 14, 2004, 10:36:29 AM »
What the best way to check that? Pull the fuel line?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #5 on: September 14, 2004, 10:42:44 AM »
Can I just pull the return line?Will that be accurate? Its a lot easier to get to.
Mike
Offline 1bigtracker
  • 3409
« Reply #6 on: September 14, 2004, 11:27:48 AM »
you should be able to hear it turn on when she turns the key on.
stu
  • 6598
  • 68
« Reply #7 on: September 14, 2004, 11:43:34 AM »
Mike
Yeah, that would work for starters. You may be able to have someone stick there head down by the gas tank while it's cranking and listen for the pump to be running. If it's not, I'd get a long piece of wire and run a simple jumper wire from the positive of the battery to the plug in on top of the tank (that's pretty easy to get to) The pump will run non-stop then and if it's a fuel problem it'll fire up after that...
  • 6598
  • 68
« Reply #8 on: September 14, 2004, 11:46:16 AM »
stu
I think that depends on the year. On my '89 the pump didn't turn on until the start signal was received from the turning of the key. Then once the engine was started and had oil pressure, the ECM kept the fuel pump relay active.
I believe There's two inputs to the power relay for the fuel pump. If I had my manual on me, I could verify. ;)
Offline jerryp58
  • 449
« Reply #9 on: September 14, 2004, 01:14:15 PM »
Is this multi-port or throttle body FI?
The nice thing about my throttle body FI is that you can just look down the throttle body and see if the injector is firing.
Jerry
Offline idaholwb
  • 772
« Reply #10 on: September 14, 2004, 04:34:37 PM »
 Another thing you might want to try is check the fuel filter. It might be dirty enough to have low initial pressure.
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #11 on: September 14, 2004, 09:07:12 PM »
Maybe a dumb question but how old is the fuel?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #12 on: September 15, 2004, 09:47:03 AM »
Its new :(
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #13 on: September 15, 2004, 09:48:02 AM »
it has fresh fuel.
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #14 on: September 15, 2004, 09:51:10 AM »
It is a throttle body and their is no spray. Im waiting for her to get home to check the fuel pump.
Mike
