Oil out the exhaust
  • 2542 Views
Offline cstello
  • 33
Oil out the exhaust
« on: August 14, 2009, 10:30:45 AM »
My Sammy blows oil out the exhaust. Does that mean the rings are going out?
Re: Oil out the exhaust
« Reply #1 on: August 14, 2009, 11:26:27 AM »
Rings, it could also be valves.  How much oil do you go through and what is your compression like?
Offline zukimoo
  • 330
« Reply #2 on: August 14, 2009, 01:09:01 PM »
check the compression, that will tell you alot but oil out of the exhaust is not a good sign.....
06 Baja Buggy
« Reply #3 on: August 14, 2009, 05:26:10 PM »
Dripping? or just smoking?
If it's dripping and it's oil yikes
or could it be water vapor condensing and dripping out?
Offline cstello
  • 33
« Reply #4 on: August 17, 2009, 08:28:04 AM »
Not dripping or smoking. It does use some oil and it leaves a black splatter on my driveway by the exhaust. What pressure on the compression should I have?
« Reply #5 on: August 17, 2009, 01:40:47 PM »
Are you sure the splatter is oil?
I've seen situations where a vehicle burning moderate amounts of oil will have a carbon build up in the exhaust and condensation from a cold start will blow a wet black splatter - essentially a misture of water & soot - from the exhaust.
What pressure should you have?  Depends on how tired the engine is - by the book 150 psi is the low figure for a 1298cc G13BA - but they will run surprisingly well with a lot less than that - I have one here that's 100~120 depending on which cylinder you're measuring - starts well, runs well, uses about a quart every 3000 miles.
« Last Edit: August 17, 2009, 01:46:55 PM by fordem »
« Reply #6 on: August 18, 2009, 10:05:50 AM »
Those black spatters are water, not to worry, drive and enjoy your
trucklet, but keep an eye on the oil always at each gas fillup
