rear dif
  • 17 Replies
  • 3549 Views
Offline bus_driver
  • 479
rear dif
« on: March 13, 2005, 03:19:26 AM »
hey guys I am a new member thanks for having me here
I have a question .....I was at the wreckers and found a rear diff with some sort of cable mounted in just above the drive shaft ....what is it cuz mine don't have it.....did any of these have a cable locker?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline 1bigtracker
  • 3409
Re: rear dif
« Reply #1 on: March 13, 2005, 03:23:51 AM »
r u talking about a sammy or trac/kick axle?
are you thinking of the vent hose?
They never made a cable locker for the sammy or trac/kick
They do make a ARB air locker that has a hose running to it.
other than the parking brake or brake lines i can't think of anything.
stu
Offline mesjr2004
  • 422
Re: rear dif
« Reply #2 on: March 13, 2005, 04:08:46 AM »
could it have den the wires for the speed sensor?
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: rear dif
« Reply #3 on: March 13, 2005, 05:17:52 AM »
speed sesor wire is on the tranny or t-case on samis and kicks. don't know does it feed int the diff or just mounted on it and running some where else.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Re: rear dif
« Reply #4 on: March 13, 2005, 07:23:25 AM »
ABS/ALB sensor
Re: rear dif
« Reply #5 on: March 13, 2005, 07:41:42 AM »
Parking brake cable on a Sammy ?
Offline bus_driver
  • 479
Re: rear dif
« Reply #6 on: March 13, 2005, 11:59:28 AM »
this was on a kick axle where the rear shaft enters the housing. directly above the shaft there is a bracket and cable running into it and into the diff.....the other end runs up into the body .....but it is not the breather  ?????
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline real_red_wagon
  • 226
  • Make It Hert!!!
Re: rear dif
« Reply #7 on: March 13, 2005, 12:22:59 PM »
  I've seen this once before on a trade in at the dealership I didn't look to cloesly but I thought it might have been some sort of driveshaft disconnect as it had all the flat towing hardware on it. the truck was a real pile and the dealership had too much money into it so like I said I really didn't look to cloesly at it :-/
At Lakeview Motorsports, were wasting your time already!
Offline 1bigtracker
  • 3409
Re: rear dif
« Reply #8 on: March 13, 2005, 12:23:11 PM »
do you have a digi cam?  i think we are going to need a pic for this one.
stu
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
Re: rear dif
« Reply #9 on: March 13, 2005, 06:05:18 PM »
Any or you folks remember reading about german sj413's  with the drive line ebrake having a cable acutated locker?
87 Samurai
mudfkr
Re: rear dif
« Reply #10 on: March 13, 2005, 07:16:23 PM »
Oh yeah the Wouter diff lock, http:// http://www.euronet.nl/~icu05161/sper_e.html
I'm supposed to be going to Germany in May for work related crap, I'll have to keep my eye out for a 413  ;).
« Last Edit: March 13, 2005, 07:18:11 PM by mudfkr »
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: rear dif
« Reply #11 on: March 13, 2005, 07:23:18 PM »
Don't bother getting one they aren't strong enough to be used off-road  :( But if you are able to modify it it can be made stronger... ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
mudfkr
Re: rear dif
« Reply #12 on: March 13, 2005, 07:46:13 PM »
I've read different opinions of how Strong they are and if they are suitable to be used as a off road locker, some say yes and others disagree.  Personally I'm an ARB boy  ;) and can't ever see that changing but I still be interested in having a look at one just for the sake of it, after all it's zook related so it's got to be better than work related stuff  ;D
Offline mbmarkyb
  • 461
    • UK Vitara
Re: rear dif
« Reply #13 on: March 13, 2005, 09:45:48 PM »
didnt he say it was a kick axle, My money is on a Anti locking brake sensor,
When you take it out it will have an extra plate bolted in with the crown wheel with lots of teeth,
Only reason I know is I took one out of a tracker over here and it had that setup.
Markyb (UK)
UK Vitara JLX SE
Re: rear dif
« Reply #14 on: March 14, 2005, 02:02:34 AM »
If it comes out of the housing, and not
the 3rd member, it's the breather, they
are vented into the body on a SideKick
