Track/Kick Slip Yoke Eliminator Started
wildgoody
8134
67
January 22, 2006, 12:02:22 AM »
Got the output shaft out of the T-case and
in for machine work, will see if the center of
the shaft can be drilled and tapped to accept
a 3/8" Bolt for a flange mount Yoke
Installing this Kit will require removal of the
T-case and swapping of the output shaft, not
too bad of a job, but requires almost a complete
T-case disassembly
The kit will include
Machined output shaft
New Slip Spline Drive Shaft
Estimated Cost has yet to be determined
Comments, questions Reply Here or PM/E-mail
me (info in my Bio)
Cwkick
888
Re: Track/Kick Slip Yoke Eliminator Started
January 23, 2006, 06:47:53 AM »
How about some pictures??
Cwkick
dave
31
I love YaBB 1G - SP1!
January 23, 2006, 01:34:56 PM »
I don't know of the flange will fit but the shaft can be drilled. (I've did it in my dual T-case project.)
wildgoody
8134
67
Reply #3 on:
January 23, 2006, 02:04:35 PM »
Yes, it works, I wouldn't post and get your hopes up
hcgalvin
1695
Roads? Where we're going, we don't need roads.
Reply #4 on:
January 25, 2006, 08:21:35 AM »
BTT
Any news?
Heather Galvin
wildgoody
8134
67
Reply #5 on:
January 25, 2006, 08:29:02 AM »
Well I'm either going to try a Cobalt drill bit
or I have to get a Carbide tipped drill bit to
cut the hard outer on the shaft Rockwell 65-80
is a tough cut, once that's done, it should progress
rapidly.
I hoped Earny had the right drills, but he said he
didn't have any that were the right size to cut threads
after, hole size is critical for thread performance
Cwkick
888
Reply #6 on:
January 25, 2006, 10:11:02 AM »
Quote from: wildgoody on January 25, 2006, 08:29:02 AM
UUUUHHH.........Nevermind
Cwkick
ppltrak
654
zukspeed staff
Reply #7 on:
January 26, 2006, 09:02:34 AM »
Darren, Keep me informed on this mod. I'm interested
Kevin
94 purple/green splash tracker w/ calmini 3' heavly modified lift 32 11.5 r15 bfg m/t's & custom air induction and header w/ 2"exh. no cat lockrite rear 2" B/L and a heavy right foot and now 583s steel up front and locked.
wildgoody
8134
67
Reply #8 on:
February 03, 2006, 11:22:32 PM »
Tried a special drill bit tonight, it's
supposed to cut hardened steel
and glass and ceramic, well it made
some progress, as sparks were flying,
but the tip shattered from some viberation.
I'll try another bit tomorrow,
This is some tough stuff
hcgalvin
1695
Reply #9 on:
February 21, 2006, 10:04:21 AM »
BTT
How's it going? I have a couple people here who are interested in hearing the status of this project. They want to go SAS.
Heather Galvin
wildgoody
8134
67
Reply #10 on:
February 21, 2006, 10:12:05 AM »
SAS
J/K
I wasen't working on the front output,
but I suppose that could be done too
The shaft is some hard stuff, I still need to get
the replacement drill, I might have to order a
special Carbide bit that is designed to cut R60+
hardness steels.
jason hutchison
495
5
ZUKIWORLD Staff
Reply #11 on:
February 24, 2006, 01:51:37 AM »
you could get it EDMed. Basically burn through the steel with electricity. shouldn't be too expensive either.
mbmarkyb
461
Reply #12 on:
February 24, 2006, 02:59:14 AM »
I tried to do this to the front output shaft on my sammy live axle conversion.
4 drill bits and 3 hours and it hardly shifted it, another guy here tookt he case to a milling shop and they charge 20 quid but said they ruined 4 millling bits to get it done and wouldnt do another ,
tough old gears , I basically got the prop to the limit length that does the job on holing it in place , it is a sammy/kick cross prop with the slip yoke in the middle too so it has enough momvent without pulling it out the t case
Markyb (UK)
UK Vitara JLX SE
