Shift on the fly 4wd - sammi
Indy
December 11, 2007, 08:46:51 PM »
Does the sammi tcase suffer any damage by shifting from 2wd to 4hi and back while moving w/o using the clutch? I'm assuming I don't need to come to a complete stop or anything.
Freak
Re: Shift on the fly 4wd - sammi
December 12, 2007, 07:52:25 AM »
It's best to use the clutch but you don't need to stop!
lil_Truck
1148
Eric Gardner
December 12, 2007, 10:13:38 AM »
As long as the front end is locked in, no.
The case does not have a sincro (sp?). So as long as the front drive shaft and rear drive shaft are going the same speed, there's no problem. If there not you will feel the gears grinding.
96 Tracker
32 MTR's Warn 8000i
Indy
Reply #3 on:
December 12, 2007, 01:21:06 PM »
Thanks for the info. I think this is my first ride in about a decade that wasn't full shift on the fly, couldn't remember if I was doing it right
I'm once again enjoying everything that manual hubs has to offer.
