Side draft
  • 7 Replies
  • 2364 Views
Offline Amilla
  • 1076
Side draft
« on: May 14, 2007, 08:43:32 AM »
I was thinking about going with a side draft carb set up.  I have an 88 sammi.
I was woundering if anyone has ever run a side draft or know anyone that has run them.  Are there any cons to this carb set up?  I have heard some people say that they can be pretty boggy as low speeds due to the intake not being able to pull the fuel in at lower RRMs.  But i have also heard that they have very snappy throttle response.
Any information would be great.
Amilla
Offline blakester1123
  • 95
  • 88 sammy 6in on 32s and rising
Re: Side draft
« Reply #1 on: May 14, 2007, 09:49:07 AM »
i would save a little more and do a 1.6 swap you wont regret it 8v or 16v
Offline Amilla
  • 1076
Re: Side draft
« Reply #2 on: May 14, 2007, 11:15:41 AM »
I can do the side draft carb for about 350 bucks.
But and engine swap has been in the back of my mind for a while, i will most likely do an engine swap later on but for now im going stick with the mighty 1.3L
Amilla
Re: Side draft
« Reply #3 on: May 14, 2007, 11:22:27 AM »
I have a side draft on my SJ-410 and I love it.  You don't stall out while climbing like the traditional carb setups.  :)
Not sure about issues, but one of the guys I used to wheel with used a side draft on a Toyota that has a nasty habit of causing the head to burn valves up unless it was tuned just right.  He ended up switch to injection after a year or so.
Re: Side draft
« Reply #4 on: May 15, 2007, 05:36:07 AM »
Which carb are you considering? The SU carb swap is very popular in the UK usually using a 90 degree adapter. The adapters do suffer from carb icing in the winter though so a properly converted manifold is a better option. If the carb is set up right it doesn't matter whether its sidedraught or downdraught, the fuel still has to be pulled up from the float chamber.
  • 6589
Re: Side draft
« Reply #5 on: May 15, 2007, 09:10:57 AM »
Amilla
From the ZUKIWORLD Archives:
http://www.zukiworld.com/month_050102/feature_dcoesetup.htm
And the ZUKIWORLD Gear Guide:
http://www.zukiworld.com/month_060101/feature_reynolds_01.htm
I've run'em and I like them. There are things to do for set up but once they're dialed in, they are great and the webers are rock solid; no further adjustments needed.
Offline Amilla
  • 1076
Re: Side draft
« Reply #6 on: May 15, 2007, 10:08:20 AM »
Hey thanks for all the information about them.
I havnt decided what carb i should run yet, any one got any ideas on that?
Thanks again
Amilla
  • 6589
Re: Side draft
« Reply #7 on: May 15, 2007, 10:49:32 AM »
Thanks again
Amilla
Depends on use of vehicle and desired out come.
