TrailTough Front Locker
  • 38 Replies
  • 10168 Views
Offline TysonS
  • 383
  • www.funinbc.com
Re: TrailTough Front Locker
« Reply #30 on: December 11, 2006, 06:03:55 PM »
i wouldn't waste my time with the auto hubs..
ok, next question.  I have a 1991 suzuki sidekick with a 8v standard tranny.  With the locker in the rear and 31" LTB's will i have any power/toqure to turn those tires with the stock gearing?  Should i get TT tcase gears first or get a locker for the front? because i notice that when trying to start from a stop when turning you really have to hit the happy pettle to stop if from stallingwith the locked rear, and im thinking with the locker in the front this would make it even worse?
any opinions?
Offline chet
  • 556
  • Zuki time!
« Reply #31 on: December 12, 2006, 09:02:45 AM »
A locker will not make it any harder to drive power wise. the reason you have to give it gas to keep from stalling it the 31" tires and stock gearing. TT tcase gears before locker is my opinion. Unless you only do mud or dunes then front locker!
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #32 on: December 12, 2006, 02:22:52 PM »
mostly run trails, off camber stuff and washouts.  some mud.
if im ordering the tcase gears from TT i will probably save up a little longer and order the TrailTough tcase gears and the front locker to save on shipping and duties.
Offline darkd
  • 19
    • offroadfun.de
« Reply #33 on: February 08, 2007, 12:02:45 PM »
|removethispart|@FNG:
Who is STAN???
Didn´t find anything here on zukiworld.
Thanx Dan
i am running the kit that stan makes.you use stock toy cv shafts and locking hubs you do mike hagen's widening the kit comes with hub adapters new bushings and adapter plates.
you bolt one plate to the drivers axle and then you cut the passenger side inner cv cup and weld the adapter to it.the kit is top notch and comes with all hardware and instructions.
Suzuki Sidekick 1,6 8v Supercharged
www.offroadfun.de
We don´t need any Roads!
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #34 on: February 08, 2007, 12:27:40 PM »
Gears before locker.  Even if you have the front locker first, your gearing is so off that you'll end up burning you clutch out and breaking axles from going to fast.
The lockers and ring & pinion gears (5.62's) were put in at the same time and that was okay.  But still, when it came to tougher climbs, the ole clutch got one hell of a workout.  Now that I have installed the 4.24 t-case gears, what a difference.  I loved it when I was climbing up hills and rock outcrops that the jeeps were having one hell of a time climbing...and I noo problem even with my A/C on ;D  It just crawls under minimal power.  So I would recommend the gears.  Good luck!
Aaron
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
« Reply #35 on: February 09, 2007, 06:52:48 AM »
Who is STAN???
Thanx Dan
stan is the person who makes this kit  http://www.zukiworld.com/forum/index.php?topic=9229.0
if you need more info send a pm
Offline ROSS
  • 1412
« Reply #36 on: February 09, 2007, 06:59:19 AM »
his name is 37kicker. pm him
Offline darkd
  • 19
    • offroadfun.de
« Reply #37 on: February 09, 2007, 07:01:00 AM »
thx.
www.offroadfun.de
Offline FNG
  • 197
« Reply #38 on: February 09, 2007, 10:07:00 AM »
thanks i could not remember his screen name ::)
« Last Edit: February 09, 2007, 10:11:06 AM by FNG »
