tires and diffs
tires and diffs
bus_driver
479
the voices tell me different things
tires and diffs
May 31, 2005, 07:11:47 AM »
ok I know other people are asking about largest you can put on with lifts and others are asking what gears if I .......
All I want to know is if I want to keep my trucklet gears stock can I use 30-9.5-15 tires without bogging or revving and slipping the clutch all the time.....I like the gearing with the stock tires will it be almost the same with 30"
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Bobzooki
1754
2
Web Wheeler
Re: tires and diffs
May 31, 2005, 07:38:02 AM »
You should be fine.
I ran 31's for quite awhile, with no regearing or lockers.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
bus_driver
479
Re: tires and diffs
May 31, 2005, 08:27:32 AM »
sweet cuz i am looking at the chunky look and I was thinking of a one inch body ( I don't like body lifts that much ) with the 2" suspension just too clear everythign and when i find a deal getting the 2.5 bs wheels
92 2dr soft top
235/75/15
2 inch lift
custom mud
chet
556
Zuki time!
Re: tires and diffs
Reply #3 on:
May 31, 2005, 08:40:14 AM »
I have 2" of coil lift and 30's right now and ever so lsight rubbing in the front turned lock with 15x7 black steel rims with 3.75" of back space.
DirtDevil
317
Island4x4.com
Re: tires and diffs
Reply #4 on:
May 31, 2005, 10:15:54 AM »
3.75 seems to be about ideal for tracker backspacing, stock suzuki sami wheels work very well on a tracker, my gfs got 31x10.5 " trxus mts and they only rub at full turn/stuff on the front with only a 2" coil spacer lift, no body lift.
Sj410 Full exo, Locked, race buckets, 5 point
85.5 LWB sami, Toy axles, locked rear, CJ/RUF, warn 8000, 33's
92Sidekick4x4
1456
Spencer Atkinson, 92Sidekick4x4
Re: tires and diffs
Reply #5 on:
May 31, 2005, 10:35:35 AM »
how do i measure what the back spascing is?
my lug nuts require more torque then my engine makes
Cwkick
888
Re: tires and diffs
Reply #6 on:
June 01, 2005, 01:54:48 AM »
I am running 235's (29") tires on my 97 16v. I like the gearing much better than with stock tires. I know Agent Orange has 30's on his and has no complaints. I would think you would be just fine with 30's.
Cwkick
92Sidekick4x4
1456
Re: tires and diffs
Reply #7 on:
June 01, 2005, 12:13:42 PM »
i run 30's on mien right now, no problems
bashzuk
784
Been zuked lately!!!
Re: tires and diffs
Reply #8 on:
June 01, 2005, 02:08:57 PM »
Take a tire face it so that the side that mounts to the rig is up place a piece of wood or metal so that it only touches the rim
,make sure it is flat, lay across the rim and measure to the bolt hole surface in the middle of the rim that will tell you your back spacing.
Mean Green Wheeling Machine
SidekickMN
58
Waiting on Money for Body Lift
Re: tires and diffs
Reply #9 on:
June 01, 2005, 02:37:18 PM »
bus i am currently runing 30x9.5x15 on stock i dont have a problem boging down and i have not incontered eny rub when offroading.
1994 Sidekick, hard top, soft top, custom bikini top
30x9.5x15 mud tires
RRO 2.5"
Herculiner interior
Craw4x4PH
121
www.4x4ph.com
Re: tires and diffs
Reply #10 on:
June 01, 2005, 11:49:11 PM »
I'm running on stock gears with 30" tires. No problem.
[/url]
[/url]
bus_driver
479
Re: tires and diffs
Reply #11 on:
June 02, 2005, 09:45:52 AM »
sweet now I can go to my heep friends and find out who has taken the wranglers off one lately untill I have the money for the mudders.....and the lift goes on about the same time as the wranglers since they also have xj springs for my rear
yeee haaaa!
92 2dr soft top
235/75/15
2 inch lift
custom mud
Craw4x4PH
121
www.4x4ph.com
Re: tires and diffs
Reply #12 on:
June 02, 2005, 11:21:16 PM »
Don't forget the pics of the buildup... and the finished product
[/url]
[/url]
Natebert
1098
Re: tires and diffs
Reply #13 on:
June 03, 2005, 05:51:57 AM »
You'll notice a difference between stock and 31's but to us it was tolerable.
Anything larger and you'll definitely want gears.
