calmini roof rack
  • 4060 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
calmini roof rack
« on: February 04, 2004, 08:00:30 AM »
I am thinking about buying the Calmini roof rack, Ihave read nothing but good stuff. But I do have a question regarding the soft top and will the front still open and close like without the rack? ???
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: calmini roof rack
« Reply #1 on: February 04, 2004, 08:21:16 AM »
I've thought about that one myself.
Offline wolf66
  • 193
« Reply #2 on: February 04, 2004, 08:49:07 AM »
Yeah i want one too, but its $450 + $100 S&H to Fla ....painful
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
  • 6602
  • 69
« Reply #3 on: February 04, 2004, 09:25:54 AM »
This may help:
http://www.zukiworld.com/month_120102/feature_gearguide_calminiroofrack.htm
I don't think you could use the hinge mechanism to fold the front back for the 'sun roof' action. However, Jason could take his hard top piece off quite easily.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: February 04, 2004, 03:27:52 PM »
Ya, thats what I thought. Ijust wondered if anybody tried it and does the "sun roof" still work. :-/
Offline speedytang
  • 78
« Reply #5 on: February 04, 2004, 08:02:18 PM »
All the Jeep carriers have hinges on the rear and you just tilt it back to lower your top or remove the hardtop and put it back and it latches in the front. I think that rack unit needs more engineering and a much lower price.
« Reply #6 on: February 04, 2004, 11:05:28 PM »
I have a Steelhorse cage on Suzuki roof bars. Overall I guess its similar to the Calmini set up just implemented differently. I have a one piece top with removeable windows. The front section won't go back as it originally did but there is still enough room to remove the top. You could always fit some arrangement to the front of the rack to hold the softop back if you wanted to use it in 'sunroof' mode
