why my heat/air fan only on high?
  • 7 Replies
  • 2565 Views
Offline mattstracker
  • 43
« on: May 16, 2011, 04:07:54 PM »
I have a 96 Geo Tracker my blower motor only works on high. Why?
Offline smife
  • 179
Re: why my heat/air fan only on high?
« Reply #1 on: May 16, 2011, 04:45:36 PM »
The little resistor on your blower motor is bad
« Reply #2 on: May 16, 2011, 05:34:45 PM »
The fan speed is controlled by a resistor and a switch - either one of them (or the wiring) is your problem.
« Reply #3 on: May 16, 2011, 09:15:03 PM »
I had the slower speeds stop working, re-soldered the wires
onto the switch and it works again
  • 43
« Reply #4 on: May 16, 2011, 09:36:02 PM »
where is the little resistor at on the blower motor?
« Reply #5 on: May 16, 2011, 09:42:57 PM »
Those are resistor wires, and the air blows over them
to keep them cooled off, otherwise they would turn
red from the heat
  • 43
« Reply #6 on: June 08, 2011, 09:23:13 PM »
got it working took it apart sprayed it with electric cleaner. works great on all speeds.
Offline zuk1988
  • 19
« Reply #7 on: June 09, 2011, 07:32:55 AM »
That happened to my switch too.
88 Samurai,1.6 16 valve,D44 front Ford 9" rear,33 swamper TSL's
